Rhino 8.15 (SR15)
Rhino 8.15 (SR15) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
请浏览这里
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包;
- 下载离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 点击这里进入百度网盘下载
链接: 点击这里进入百度网盘下载
- Tags are crashing in the textures panel (RH-85018)
- BlockEdit: Pop up a warning when called from a python script (RH-84753)
- BoxEdit: Scrolling in a value box also scrolls the panel (RH-79594)
- Code Editor Control:
- Displacement:
- Display: Grasshopper Preview in Artic mode fails on complex geometry (RH-85072)
- Edit Dimension: Aligned Dimension not staying on dimension plane (RH-85028)
- File IO: Pasting Causes Error Missing Patches (RH-84407)
- FilletSrf: Left a gap at closed seam (RH-83961)
- FilletSrfToRail:
- Flip: Does not work on a surface if a point is also selected (RH-84825)
- Grasshopper:
- Gumball: Extrude is slow with many objects (RH-84804)
- History:
- Keyboard Shortcuts: Dialog needs focus (RH-84730)
- Layer: Material name and preview don’t refresh (RH-85168)
- MatchProperties: Hatch Border is Missed (RH-84858)
- Mesh: Changing Mesh dialog from Simple to Detailed doesnt stick when returning (RH-85081)
- NamedSelections:
- NamedView: Animation jumps at last frame (RH-83752)
- OSnap: No Snap in Clipped Scene (RH-84977)
- PlaceCameraTarget: Tilts view if negative Z axis is up (RH-85043)
- PointDeviation: Performance and UI issues (RH-85003)
- Print: Ignores Section Style Boundary Scale (RH-84895)
- Project: Loose option not creating periodic output from periodic input (RH-84803)
- Rendering: Cycles:
- Rendering: Textures: Replace texture map doesn’t work (RH-84983)
- Rhino Inside: Published GH commands do not work until Grasshopper is loaded (RH-84726)
- SDK: RhinoCommon:
- SVG Editor:
- ScriptEditor:
- Reported syntax error not shown in Script Editor (RH-84554)
- C# async code compile error (RH-85085)
- C# autocompletion does not suggest useful stuff anymore (RH-85098)
- Python3 stub maker errors on CurveComponent dependency (RH-85070)
- GH editor console collapses when info and warning buttons are clicked (RH-84867)
- Rhino pip listens to PIP_USER global env var (RH-83985)
- Allow unsafe code in C# scripts (RH-84779)
- Section Style: Hatch Patterns Display and Print Over Boundaries (RH-84883)
- Selection: Sub-Object Edge Loop Selection - Odd Behavior (RH-84736)
- ToNURBS: SubD ForceUpdateFacePacks breaks ToNurbs (RH-84973)
- Toolbar: YAK package fails to update RUI file (RH-84576)
- Undo: Wlow when material tab is open (RH-84959)
- Unwrap: Added ShowEnds option to display endpoints on selected seams (RH-84969)
- Worksession: Crash when attaching DWG files (RH-84824)
宕机修复
- File IO:
- Rendering: Cycles: Crash when wallpaper file isn’t set (RH-85149)
- ScriptEditor:
增强内容
- CPlane: AutoAlign: AutoCPlane now aligns to a planar surface edge (RH-84890)
- Centermark: Allows selecting objects in detail views from a layout (RH-62512)
- Circle: “FitPoints” option in all circular-based commands support picking a group of points (RH-84952)
- File IO: DWG/DXF Export uses relative paths for saving image files used by Picture objects (RH-46885)
- OSnap:PerpTo: Treat Perp-Cen osnap pair the same as Near-Cen pair (RH-84904)
- ScriptEditor:
- Added RunWithGHPlayer to project commands from gh files (RH-84116)
- Support hover in Python 3 (RH-85077)
- Made code snippets togglable - default off (RH-84861)
- Provide toggle to turn off C# snippets (RH-84863)
- Font variations does not work in new script editor (RH-78080)
- Added collapse all in debug variables (RH-82352)
- Debugger does not capture class props in local scope (RH-81598)
- SelNonManifold: Supports selecting Non-Manifold meshes (RH-84814)
- UserText: Changed sorting order of Block attribute / Text field / Plain text (RH-84770)
增加特征
- Radius: Allows evaluating radius on clipping section edges (RH-85127)
性能改善
- Layer: Cache Layers panel images (RH-85053)
- Displacement: Sub-object workflow regression (RH-82114)
- Display: Inverted bitmap drawing (regression)… (RH-85324)
- ExtendSrf: Locks up Rhino (RH-84459)
- Grasshopper: “Curve | Self” component fails (RH-84675)
- Mesh: Options > Mesh doesn’t apply preset in simple mode (RH-85389)
- Rendering: Materials: Editing Dialog Stays on Top of All (RH-85188)
- Subobject Selection: Picking vertices in SubD / Shaded mode is awful in 8.15 (RH-85196)
SDK 增强内容
- RDK: Added an API to get the content editor selection (RH-84443)
- SDK: Added a new RhinoSeparateBreps function to C++ SDK (RH-85074)
- SDK: RhinoCommon:
- ScriptEditor:
适应性问题修复
- Mesh: Preview mesh appearance is based on display modes and ignores object display colors and materials (RH-84741)
- ScriptEditor:
- Python 3 to set locale before running script (RH-81130)
- C# scripting: add assemblies to code completion provider on the fly (RH-72523)
- Should not complain about missing specials in commands (RH-83901)
- Project Command help needs to be there for end users (ACADIA 2024) (RH-84722)
- Component source gh file does not open on dclick (ACADIA 2024) (RH-84719)
仅 Mac 相关内容
- CommandHistory: Does not scroll to the bottom (RH-73417)
- CommandPrompt: Undocked command prompt requires extra click (RH-76524)
- Display:
- Grasshopper:
- Layout: Column width in Layouts panel does not stick on Mac (RH-85105)
- Rebuild: Span count missing label when rebuilding curves on Mac (RH-83981)
- SVG Editor: Have to press Cancel twice (Mac) (RH-84748)
- SetPt: Needs two clicks in viewport when CurvatureGraph is active (RH-71507)
- Text: Focus moves to Command-line when editing text (RH-85059)
- Viewports: Viewport: Takes 2 clicks to activate UV Editor viewport on Mac (RH-80982)
宕机修复
- Rendering: Materials: Crash occurs when editing an instanced child texture (RH-55423)
- Export: STL export settings have too much padding (RH-85240)
适应性问题修复
- Grasshopper: Improving editing of long layer names in Geometry Pipeline (RH-67813)
- UI Cleanup: Improved accessibility of command options (RH-84437)
仅 ❖ 版相关内容
- ChangeLayer: Dialog size is reset by Purge command (RH-78621)
- Dark Mode: SaveAs PDF custom units not visible (RH-69622)
- Document UserText: Hang When Collapsed Sidebar is Used (RH-85042)
- Installer: Zoo server registry key is deleted when updating Rhino (RH-85020)
- RDK: Bogus (.jpeg) and (.tiff) entries in drop-down list (RH-84800)
- Rendering: Texture Mapping: Texture mapping Properties page delays viewport manipulation (RH-85323)
- TextObject: Toggling case setting resets font to Arial (RH-47587)
- Display: Curve display regression in Parallels (RH-84957)
