Rhino 8.34 (SR34)
Rhino 8.34(SR34) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- Block: Rotating certain block instances causes weirdness (RH-87620)
- Display: Rotation preview incorrect for far-from-world-origin objects (RH-96717)
- File IO: SVG import produces an error at the seam of a closed polycurve path (RH-96250)
- Grasshopper: Dim Text Override is Not Displayed (RH-95142)
- Hydrostatics: Center of Buoyancy coordinate has a space between X and Y values, preventing copy-paste as a point in Rhino (RH-96576)
- PackageManager:
- Rendering: Materials inconsistency between Raytraced and Rendered viewports (RH-91045)
- ScriptEditor: BaseScriptComponent.SetSource affects component language (RH-96540)
- SDK: Python: rs.ObjectLayout(obj) moves objects (RH-96724)
- SDK: RhinoCommon:
- TextField: Detail Scale Text Field Incorrect in Metric (RH-96873)
- Viewports: Ctrl + Tab no longer works to switch between viewports (RH-70582)
宕机修复
- Core Architecture: Eto.Wpf.Forms.Controls.WebView2InitializationException: Failed to initialize WebView2 (RH-95640)
- Display Metal: com.mcneel.rhinoceros.RhCore:invocation function for block in CRhMetalEncoder::Present(CRhMetalLayer*) (RH-96516)
- Layer:
- MeshRepair: System.ArgumentNullException: Value cannot be null. (Parameter ‘objRefs’) (RH-96918)
- No Subsystem: opennurbs!ON_Curve::EvPoint – (RH-96297)
- Rendering: Cycles:
- Select: Crash in curve sub-object picking when object is not in doc (RH-96887)
- Rendering: Cycles: Bongo video textures render black (RH-94515)
开发工具增强
- SDK: Allows enabling history update on changes of object properties (RH-64486)
仅 Rhino Mac 相关
错误修复:
- File IO: -Save command does not save a file on Mac (RH-96747)
- PerFaceDisplayColor: Color Per Face Irregularities (RH-93960)
宕机修复:
- Splash and Greet: Mac: Rhino 8 hangs forever at startup/reopen when macOS recent-files resolution stalls – MRChooser blocks the main thread (force-quit reports as “FATAL NATIVE CRASH: term”) (RH-96750)
❖ 仅 Rhino Windows 相关
错误修复:
- Exit: “Close Window” from taskbar locks up Rhino App (RH-96115)
增加特征:
- Installer: Added RhinoInstallRepair.exe tool to Rhino 8.34 (RH-96667)
