Rhino 8.35 SR35 发布更新
:rhinoceros: Rhino 8.35 (SR35)
Rhino 8.35(SR35) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
  1. 请浏览这里 :point_left:,输入你的Rhino账号绑定的邮箱地址,下载更新安装包;
  2. 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
    ❖ 百度盘下载链接 :backhand_index_pointing_left:
  3. 下载 Mac 版离线完整安装包
    :green_apple: 百度盘下载链接 :backhand_index_pointing_left:
:cross_mark_button: 错误修复
  • AttachGHSData: Where does AttchGHS data live in the model (RH-86323)
  • BlockManager: Editing on large selection bug (RH-97687)
  • BoxEdit:
    • Gumball and Cplane (RH-95015)
    • Panel Position Coordinates Don’t Track CPlane Radio Button (RH-97495)
  • CurvatureAnalysis: Preview does not work in meshing options (RH-86382)
  • Display:
    • “Print Preview” Line weight Too Thick (RH-95098)
    • Curves are thickening when zooming out (RH-83262)
    • Section Background Becomes Black (RH-88191)
  • Display Metal: Hatches with no lines abort the Metal display (RH-97391)
  • DraftAngleAnalysis: ExtractAnalysisMesh outputs wrong vertex colors for draft angle (RH-96404)
  • File IO: STEP import drops duplicate instanced parts (RH-97637)
  • LayerStateManager: Import file dialog defaults to “(null)*.3dm” (no files shown) (RH-97107)
  • Linetype: Tessellation is different between World Units and Pixel units (RH-87569)
  • MeshSplit:
  • OpenNURBS: Author a view’s construction plane and grid (RH-97832)
  • PackageManager: Yak cache command builds invalid cache for packages in sub dirs (RH-97194)
  • Print:
    • Linetype Not Printing Vector On Solid (RH-95120)
    • Print window misaligned (RH-91214)
    • Line width scale has no effect on section boundaries (RH-96390)
    • Text-Mask missing in PDF (RH-82586)
    • Dash-dot lines have inconsistent segments and endpoints in PDF (RH-96551)
  • PrintPreview: Displays incorrect hatch pattern thickness (RH-82070)
  • Properties: Properties panel “By View” cannot remove an all-viewports display mode override (as set by GH Model Object / Content Cache) — dropdown snaps back to the override (RH-96944)
  • ReduceMesh: NullreferenceException (RH-97579)
  • ScriptEditor: Project publish does not add .resources file to solution (RH-97297)
  • SDK: RhinoCommon:
    • DisplayPipelineAttributes.UseSectionStyles inverted (RH-97671)
    • Crash when joining breps from a deferred query (RH-97586)
    • FindClippingPlanesForViewport does not return hidden clipping planes (RH-97156)
    • Layer.SetCustomSectionStyle() silently does nothing on a document layer (RH-97334)
    • Add/remove alias silently resets Display Mode list at next check (RH-97159)
  • Splash and Greet: Splash: unobserved ArgumentNullException in SplashSettings.GetAbsoluteUri when machine is offline (RH-97046)
  • StatusBar: Layer popup acts on wrong layer (RH-97376)
  • SVG: SVG export is bad at 1:1 (RH-94527)
  • Templates: Small Objects - Inches Template Wrong (RH-97797)
  • WalkAbout: Elevator up/down buttons move the camera in the same direction (RH-77530)
:cross_mark: 宕机修复
  • Cap: Command - Cap Command: com.mcneel.opennurbs:ON_Brep::IsManifold(bool*, bool*) const (RH-97116)
  • DocumentProperties: UnsafeNativeMethods.ON_3dmConstructionPlane_Copy (IntPtr pCP, Plane& plane, Double& gridSpacing, Double& snapSpacing, Int32& gridLineCount, Int32& gridThickFreq, Boolean& depthbuffered, IntPtr pString) (RH-97205)
  • No Subsystem:
    • Offset Command: opennurbs!ON_PolyCurve::Append – (RH-97377)
    • RhinoCore!CRhEngine_GL21::DrawOglMeshHelper – (RH-97115)
    • mfc140u!CWnd::PreTranslateMessage – (RH-97358)
  • Print: Command: System.AccessViolationException: 尝试读取或写入受保护的内存。这通常指示其他内存已损坏。 (RH-97221)
  • RDKCrash: UnsafeNativeMethods.Rdk_RenderMaterial_SimulateMaterial (IntPtr pMaterial, IntPtr pSim, CRhRdkTextureGenConsts textureGen) (RH-97211)
  • SDK: RhinoCommon: UnsafeNativeMethods.ON_Brep_DuplicateEdgeCurves (IntPtr pConstBrep, IntPtr pOutCurves, Boolean nakedOnly, Boolean nakedOuter, Boolean nakedInner) (RH-97213)
  • WindowLayout: System.NullReferenceException: Object reference not set to an instance of an object. (RH-97588)
:rocket: 性能改善
  • Grasshopper: annotation preview bounding box explodes text outlines on every solution — severe slowdown in 8.33 (regression from RH-96024 fix) (RH-97188)
:multiply: 重现错误修复
  • Display: Layout Display In V8 Looks Terrible (RH-80680)
  • TextField: Detail Scale Text Field Incorrect in Metric (RH-96873)
:hammer_and_wrench: 开发工具增强
  • SDK: RhinoCommon:
    • Author a font by name that is not installed locally (expose FontFromRichTextProperties) (RH-97829)
    • Exposed document distance display mode (RH-97163)
:clipboard: 任务达成
  • Licensing: Behavior: Wire CloudHost entitlement check into IsRhinoAllowedToRun (Marketplace license-gate enforcement) (RH-96585)
  • Localization: Sync localization submodule for 8.35 (RH-97711)
:artist_palette: 界面调整
  • Options: Removed “Layer dialog box” setting from Colors page (RH-97105)
:white_check_mark: 适应性问题修复
  • Scale1D: Added direction restriction options (RH-97633)
:green_apple: 仅 Mac 版相关内容
  • BlockManager: Odd selection process (RH-97686)
  • Display: Text Mask Displaying Under curves (RH-77971)
  • Import: File drag and drop BUG (RH-97566)
  • Print: Fake2D Fails When Layout Not “Updated” (RH-86140)
❖ 仅 Windows 版相关内容
  • ExportOptions: Dialog gets lost and locks Rhino (RH-97659)
  • LineTypeDisplay: Rhino 8 linetype regeneration fails (RH-93898)
