win10试用RhinoWIP安装有BUG,无法打开程序
win10安装rhino_9.0.26160.12305.exe和rhino_9.0.26153.12415.exe都会报错,我用DEEPseek问了一下,说是 安装失败的原因是 .NET 版本冲突
  • Rhino 安装程序要求安装 .NET 10.0.2
  • 但你已经安装了更新的 .NET 10.0.9
  • 安装程序拒绝降级,导致报错 0x80070666
    但是我重新下载了.NET10.0.2仍然无法修复。后面在WIN11上试用就不受影响。
    以下是报错日志:
    Redist_NetCore_WindowsDesktop_Runtime:-2147023258
C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119.log
[3DBC:2298][2026-06-18T12:51:16]i001: Burn x86 v6.0.2, Windows v10.0 x64 (Build 19045: Service Pack 0), path: D:\BaiduNetdiskDownload\rhino_9.0.26160.12305.exe
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘BundleVersion’ to value ‘9.0.26160.12305’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CUSTOMER_NAME’ to value ‘’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘COMPANY_NAME’ to value ‘’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘INSTALLDIR’ to value ‘’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘LICENSE_METHOD’ to value ‘’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing hidden variable ‘LICENSE_KEY’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing hidden variable ‘LICENSE_VALIDATION_CODE’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘ZOO_SERVER’ to value ‘’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing numeric variable ‘DISABLE_INTERNET_ACCESS’ to value ‘0’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing numeric variable ‘SEND_STATISTICS’ to value ‘1’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing string variable ‘RegistryRoot’ to value ‘Software\McNeel\Rhinoceros\9.0\Install’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘FolderName’ to value ‘Rhino 9 WIP’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckNETRuntime_Framework’ to value ‘Microsoft.WindowsDesktop.App’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckNETRuntime_Version’ to value ‘10.0.2’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckNETRuntime_RollForwardPolicy’ to value ‘LatestPatch’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckNETRuntime_Result’ to value ‘0’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckASPNETRuntime_Framework’ to value ‘Microsoft.AspNetCore.App’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckASPNETRuntime_Version’ to value ‘10.0.2’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckASPNETRuntime_RollForwardPolicy’ to value ‘LatestPatch’
[3DBC:2298][2026-06-18T12:51:16]i000: Initializing formatted variable ‘CheckASPNETRuntime_Result’ to value ‘0’
[3DBC:2298][2026-06-18T12:51:16]i009: Command Line: ‘-extract C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino9_26160 -y’
[3DBC:2298][2026-06-18T12:51:16]i000: Setting string variable ‘WixBundleSourceProcessPath’ to value ‘D:\BaiduNetdiskDownload\rhino_9.0.26160.12305.exe’
[3DBC:2298][2026-06-18T12:51:16]i000: Setting string variable ‘WixBundleSourceProcessFolder’ to value 'D:\BaiduNetdiskDownload'
[3DBC:2298][2026-06-18T12:51:16]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘D:\BaiduNetdiskDownload\rhino_9.0.26160.12305.exe’
[3DBC:2298][2026-06-18T12:51:16]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'D:\BaiduNetdiskDownload'
[3DBC:2298][2026-06-18T12:51:19]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119.log’
[3DBC:2298][2026-06-18T12:51:19]i100: Detect begin, 6 packages
[3DBC:7F88][2026-06-18T12:51:19]i000: OnInitializeModify
[3DBC:7F88][2026-06-18T12:51:19]i000: PrivateDetect Begin
[3DBC:7F88][2026-06-18T12:51:19]i000: PrivateDetect End
[3DBC:7F88][2026-06-18T12:51:19]i000: DetectNetCoreRuntime Begin
[3DBC:7F88][2026-06-18T12:51:19]i000: netcorecheck_path: C:\Users\AHTSPE~1\AppData\Local\Temp{EF025EED-23A4-4A90-AAB7-7E8268E5E636}.ba\helpers\NetCoreCheck.exe
[3DBC:7F88][2026-06-18T12:51:19]i000: CheckNETRuntime_Framework: Microsoft.WindowsDesktop.App
[3DBC:7F88][2026-06-18T12:51:19]i000: CheckNETRuntime_Version: 10.0.2
[3DBC:7F88][2026-06-18T12:51:19]i000: CheckNETRuntime_RollForwardPolicy: LatestPatch
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting formatted variable ‘CheckNETRuntime_Result’ to value ‘0’
[3DBC:7F88][2026-06-18T12:51:20]i000: DetectNetCoreRuntime End
[3DBC:7F88][2026-06-18T12:51:20]i000: DetectNetCoreRuntime Begin
[3DBC:7F88][2026-06-18T12:51:20]i000: netcorecheck_path: C:\Users\AHTSPE~1\AppData\Local\Temp{EF025EED-23A4-4A90-AAB7-7E8268E5E636}.ba\helpers\NetCoreCheck.exe
[3DBC:7F88][2026-06-18T12:51:20]i000: CheckASPNETRuntime_Framework: Microsoft.AspNetCore.App
[3DBC:7F88][2026-06-18T12:51:20]i000: CheckASPNETRuntime_Version: 10.0.2
[3DBC:7F88][2026-06-18T12:51:20]i000: CheckASPNETRuntime_RollForwardPolicy: LatestPatch
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting formatted variable ‘CheckASPNETRuntime_Result’ to value ‘0’
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue license_method default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue license_key default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting hidden variable ‘LICENSE_KEY’
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue license_validation_code default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue INSTALLDIR default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue customer_name default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting formatted variable ‘CUSTOMER_NAME’ to value ‘’
[3DBC:7F88][2026-06-18T12:51:20]i000: GetStringValue company_name default value =
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting formatted variable ‘COMPANY_NAME’ to value ‘’
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting formatted variable ‘INSTALLDIR’ to value ‘C:\Program Files\Rhino 9 WIP’
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue send_statistics default value = 1
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘SEND_STATISTICS’ to value 1
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue enable_automatic_updates default value = 1
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value 1
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue disable_internet_access default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘DISABLE_INTERNET_ACCESS’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_en default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_EN’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_fr default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_FR’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_it default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_IT’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_de default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_DE’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_es default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_ES’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_ko default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_KO’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_ja default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_JA’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_tw default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_TW’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_cn default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_CN’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_pl default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_PL’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_cs default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_CS’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_pt default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_PT’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetBoolValue install_ru default value = 0
[3DBC:7F88][2026-06-18T12:51:20]i000: Setting numeric variable ‘INSTALL_RU’ to value 0
[3DBC:7F88][2026-06-18T12:51:20]i000: GetSystemDefaultLangID() returned 2052
[3DBC:7F88][2026-06-18T12:51:20]i000: GetUserDefaultLangID() returned 2052
[3DBC:7F88][2026-06-18T12:51:20]i000: GetOsLanguage() returned cn
[3DBC:7F88][2026-06-18T12:51:20]i000: Showing UI from C:\Users\AHTSPE~1\AppData\Local\Temp{EF025EED-23A4-4A90-AAB7-7E8268E5E636}.ba\cn\modify.htm
[3DBC:2298][2026-06-18T12:51:20]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘10.0.19041.6093’
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘NOT ZOO_SERVER’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\6.0\License Manager’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting string variable ‘MSWebView2_Standalone_version’ to value ‘149.0.4022.69’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting string variable ‘VC2010_build’ to value ‘167812379’
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘NOT SEND_STATISTICS’ evaluates to false.
[3DBC:2298][2026-06-18T12:51:20]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\9.0\License Manager’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting numeric variable ‘MSWebView2_Standalone_exists’ to value 1
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘NOT CUSTOMER_NAME’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\9.0\Install’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting numeric variable ‘VC2015_exists’ to value 1
[3DBC:2298][2026-06-18T12:51:20]i000: Registry value not found. Key = ‘SOFTWARE\McNeel’, Value = ‘DisableInternetAccess’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting numeric variable ‘ReadDisableInternetAccess’ to value 0
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘ReadEnableUpdatesKey’ evaluates to false.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘NOT INSTALLDIR’ evaluates to false.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘ReadDisableInternetAccess’ evaluates to false.
[3DBC:2298][2026-06-18T12:51:20]i000: Setting numeric variable ‘VC2010_exists’ to value 1
[3DBC:2298][2026-06-18T12:51:20]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\McNeelUpdate’
[3DBC:2298][2026-06-18T12:51:20]i000: Setting numeric variable ‘ReadEnableUpdatesKey’ to value 0
[3DBC:2298][2026-06-18T12:51:20]i000: Setting string variable ‘VC2015_build’ to value ‘35719’
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘NOT COMPANY_NAME’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘VC2015_exists=1 AND VC2015_build>=35719’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘MSWebView2_Standalone_exists=1 AND MSWebView2_Standalone_version>=v116.0.1938.0’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘CheckNETRuntime_Result=0’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i052: Condition ‘CheckASPNETRuntime_Result=0’ evaluates to true.
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: Redist_VC2015, state: Present, cached: Yes, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: Redist_MSWebView2_Standalone, state: Present, cached: No, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, cached: Yes, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: Redist_NetCore_AspNetCore_Runtime, state: Present, cached: Yes, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: RhinoSetup.msi, state: Absent, cached: Yes, install registration state: Absent, cache registration state: Present
[3DBC:2298][2026-06-18T12:51:20]i101: Detected package: rhiexec.msi, state: Absent, cached: Yes, install registration state: Absent, cache registration state: Present
[3DBC:2298][2026-06-18T12:51:20]i199: Detect complete, result: 0x0, registration state: Full, cached: Yes, eligible for cleanup: No
[3DBC:2298][2026-06-18T12:51:22]i200: Plan begin, 6 packages, action: Repair
[3DBC:2298][2026-06-18T12:51:22]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleLog_Redist_VC2015’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_000_Redist_VC2015.log’
[3DBC:2298][2026-06-18T12:51:22]w321: Skipping dependency registration on package with no dependency providers: Redist_MSWebView2_Standalone
[3DBC:2298][2026-06-18T12:51:22]w321: Skipping dependency registration on package with no dependency providers: Redist_NetCore_WindowsDesktop_Runtime
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleLog_Redist_NetCore_WindowsDesktop_Runtime’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_001_Redist_NetCore_WindowsDesktop_Runtime.log’
[3DBC:2298][2026-06-18T12:51:22]w321: Skipping dependency registration on package with no dependency providers: Redist_NetCore_AspNetCore_Runtime
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleLog_Redist_NetCore_AspNetCore_Runtime’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_002_Redist_NetCore_AspNetCore_Runtime.log’
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleRollbackLog_RhinoSetup.msi’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_003_RhinoSetup.msi_rollback.log’
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleLog_RhinoSetup.msi’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_003_RhinoSetup.msi.log’
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleRollbackLog_rhiexec.msi’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_004_rhiexec.msi_rollback.log’
[3DBC:2298][2026-06-18T12:51:22]i000: Setting string variable ‘WixBundleLog_rhiexec.msi’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_004_rhiexec.msi.log’
[3DBC:2298][2026-06-18T12:51:22]i222: Planned rollback boundary: ‘WixDefaultBoundary’, vital: Yes, transaction: No (default: No)
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: Redist_VC2015, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, default cache strategy: Remove, ba requested strategy: Remove, cache: Vital, uncache: Yes, dependency: None, expected install registration state: (permanent), expected cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: Redist_MSWebView2_Standalone, state: Present, default requested: Repair, ba requested: Repair, execute: None, rollback: None, default cache strategy: Remove, ba requested strategy: Remove, cache: No, uncache: Yes, dependency: None, expected install registration state: (permanent), expected cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: Redist_NetCore_WindowsDesktop_Runtime, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, default cache strategy: Remove, ba requested strategy: Remove, cache: Vital, uncache: Yes, dependency: None, expected install registration state: (permanent), expected cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: Redist_NetCore_AspNetCore_Runtime, state: Present, default requested: Repair, ba requested: Repair, execute: Repair, rollback: None, default cache strategy: Remove, ba requested strategy: Remove, cache: Vital, uncache: Yes, dependency: None, expected install registration state: (permanent), expected cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: RhinoSetup.msi, state: Absent, default requested: Repair, ba requested: Repair, execute: Install, rollback: Uninstall, default cache strategy: Keep, ba requested strategy: Keep, cache: Vital, uncache: No, dependency: Register, expected install registration state: Present, expected cache registration state: Present
[3DBC:2298][2026-06-18T12:51:22]i201: Planned package: rhiexec.msi, state: Absent, default requested: Repair, ba requested: Repair, execute: Install, rollback: Uninstall, default cache strategy: Keep, ba requested strategy: Keep, cache: Vital, uncache: No, dependency: Register, expected install registration state: Present, expected cache registration state: Present
[3DBC:7F88][2026-06-18T12:51:22]i000: GetSystemDefaultLangID() returned 2052
[3DBC:7F88][2026-06-18T12:51:22]i000: GetUserDefaultLangID() returned 2052
[3DBC:7F88][2026-06-18T12:51:22]i000: GetOsLanguage() returned cn
[3DBC:7F88][2026-06-18T12:51:22]i000: Showing UI from C:\Users\AHTSPE~1\AppData\Local\Temp{EF025EED-23A4-4A90-AAB7-7E8268E5E636}.ba\cn\progress.htm
[3DBC:2298][2026-06-18T12:51:22]i299: Plan complete, result: 0x0
[3DBC:2298][2026-06-18T12:51:22]i300: Apply begin
[3DBC:2298][2026-06-18T12:51:22]i010: Launching elevated engine process.
[3DBC:2298][2026-06-18T12:51:23]i011: Launched elevated engine process.
[3DBC:2298][2026-06-18T12:51:23]i012: Connected to elevated engine.
[8AA0:55E4][2026-06-18T12:51:23]i358: Pausing automatic updates.
[8AA0:55E4][2026-06-18T12:51:23]i359: Paused automatic updates.
[8AA0:55E4][2026-06-18T12:51:23]i360: Creating a system restore point.
[8AA0:55E4][2026-06-18T12:51:24]i361: Created a system restore point.
[8AA0:55E4][2026-06-18T12:51:24]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{41709A66-D0F9-4239-A4D2-F45A5D60088A}, scope: PerMachine, options: 0x3, disable resume: No
[8AA0:55E4][2026-06-18T12:51:24]i000: Caching bundle from: ‘C:\Users\AHTSPE~1\AppData\Local\Temp{EF025EED-23A4-4A90-AAB7-7E8268E5E636}.be\Bootstrapper.exe’ to: ‘C:\ProgramData\Package Cache{41709A66-D0F9-4239-A4D2-F45A5D60088A}\Bootstrapper.exe’
[8AA0:55E4][2026-06-18T12:51:24]i320: Registering bundle dependency provider: {41709A66-D0F9-4239-A4D2-F45A5D60088A}, version: 9.0.26160.12305
[8AA0:55E4][2026-06-18T12:51:24]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{41709A66-D0F9-4239-A4D2-F45A5D60088A}, scope: PerMachine, resume: Active, restart initiated: No, disable resume: No
[8AA0:8004][2026-06-18T12:51:24]i304: Verified existing payload: Redist_VC2015 at path: C:\ProgramData\Package Cache\Microsoft Visual C++ v14 Redistributable (x64) - 14.50.35719\redist\VC2022_redist_x64.exe.
[8AA0:8004][2026-06-18T12:51:24]i304: Verified existing payload: Redist_NetCore_WindowsDesktop_Runtime at path: C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe.
[8AA0:8004][2026-06-18T12:51:24]i304: Verified existing payload: Redist_NetCore_AspNetCore_Runtime at path: C:\ProgramData\Package Cache\Microsoft ASP.NET Core 10.0.2 - Shared Framework (x64)\aspnetcore-runtime-10.0.2-win-x64.exe.
[8AA0:8004][2026-06-18T12:51:27]i304: Verified existing payload: RhinoSetup.msi at path: C:\ProgramData\Package Cache{5376CB49-2D37-43C8-89B8-7EDC329A65C1}v9.0.26160.12305\RhinoSetup.msi.
[8AA0:8004][2026-06-18T12:51:27]i304: Verified existing payload: rhiexec.msi at path: C:\ProgramData\Package Cache{1AF5B4E2-98FA-4D15-9AE7-17EFFD395B77}v9.0.26160.12305\rhiexec.msi.
[8AA0:55E4][2026-06-18T12:51:27]i301: Applying execute package: Redist_VC2015, action: Repair, path: C:\ProgramData\Package Cache\Microsoft Visual C++ v14 Redistributable (x64) - 14.50.35719\redist\VC2022_redist_x64.exe, arguments: ‘“C:\ProgramData\Package Cache\Microsoft Visual C++ v14 Redistributable (x64) - 14.50.35719\redist\VC2022_redist_x64.exe” /passive /repair’
[8AA0:55E4][2026-06-18T12:52:11]i366: The process for package: Redist_VC2015 exited with code: 0xbc2. The exit code has been translated to type: ScheduleReboot and restart: Required.
[3DBC:2298][2026-06-18T12:52:11]i319: Applied execute package: Redist_VC2015, result: 0x0, restart: Required
[8AA0:55E4][2026-06-18T12:52:11]i301: Applying execute package: Redist_NetCore_WindowsDesktop_Runtime, action: Repair, path: C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe, arguments: ‘“C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe” -log “C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_001_Redist_NetCore_WindowsDesktop_Runtime.log” /install /passive /norestart’
[3DBC:8650][2026-06-18T12:52:11]i400: Received system request to shut down the process: allowed: No, elevated: No, critical: No, logoff: No, close app: No
[8AA0:0C3C][2026-06-18T12:52:11]i400: Received system request to shut down the process: allowed: No, elevated: Yes, critical: No, logoff: No, close app: No
[8AA0:55E4][2026-06-18T12:52:12]i366: The process for package: Redist_NetCore_WindowsDesktop_Runtime exited with code: 0x666. The exit code has been translated to type: Error and restart: None.
[8AA0:55E4][2026-06-18T12:52:12]e000: Error 0x80070666: Process returned error: 0x666
[8AA0:55E4][2026-06-18T12:52:12]e000: Error 0x80070666: Failed to execute EXE package.
[3DBC:2298][2026-06-18T12:52:12]e000: Error 0x80070666: Failed to configure per-machine EXE package.
[3DBC:2298][2026-06-18T12:52:12]i319: Applied execute package: Redist_NetCore_WindowsDesktop_Runtime, result: 0x80070666, restart: None
[3DBC:2298][2026-06-18T12:52:12]e000: Error 0x80070666: Failed to execute EXE package.
[3DBC:2298][2026-06-18T12:52:12]i373: Calculating whether to keep registration
[3DBC:2298][2026-06-18T12:52:12]i374: package: Redist_VC2015, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:52:12]i374: package: Redist_MSWebView2_Standalone, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:52:12]i374: package: Redist_NetCore_WindowsDesktop_Runtime, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:52:12]i374: package: Redist_NetCore_AspNetCore_Runtime, install registration state: (permanent), cache registration state: (permanent)
[3DBC:2298][2026-06-18T12:52:12]i374: package: RhinoSetup.msi, install registration state: Absent, cache registration state: Present
[3DBC:2298][2026-06-18T12:52:12]i374: package: rhiexec.msi, install registration state: Absent, cache registration state: Present
[3DBC:2298][2026-06-18T12:52:12]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{41709A66-D0F9-4239-A4D2-F45A5D60088A}, scope: PerMachine, resume: ARP, restart: Required, disable resume: No, default registration: InProgress, ba requested registration: InProgress
[8AA0:55E4][2026-06-18T12:52:12]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{41709A66-D0F9-4239-A4D2-F45A5D60088A}, scope: PerMachine, resume: ARP, restart initiated: No, disable resume: No
[8AA0:55E4][2026-06-18T12:52:12]i420: Resuming automatic updates.
[8AA0:55E4][2026-06-18T12:52:12]i421: Resumed automatic updates.
[3DBC:2298][2026-06-18T12:52:12]i399: Apply complete, result: 0x80070666, restart: Required, ba requested restart: No
[89FC:2FDC][2026-06-18T12:52:11]i001: Burn x86 v5.0.2+dc67792d077edc24f5b197d5bd13a71e921b9396, Windows v10.0 x64 (Build 19045: Service Pack 0), path: C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing formatted variable ‘DOTNETHOME’ to value ‘[DOTNETHOME_X64]’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘BUNDLEMONIKER’ to value ‘Microsoft Windows Desktop Runtime’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘DOTNETRUNTIMEVERSION’ to value ‘10.0.2’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘DOTNETHOMESIMILARITYCHECKOVERRIDE’ to value ‘’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘VERSIONMAJOR’ to value ‘10’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘VERSIONMINOR’ to value ‘0’
[89FC:2FDC][2026-06-18T12:52:11]i000: Initializing string variable ‘MINIMUMVSVERSION’ to value ‘’
[89FC:2FDC][2026-06-18T12:52:11]i009: Command Line: ‘-log C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_001_Redist_NetCore_WindowsDesktop_Runtime.log -burn.embedded BurnPipe.{F15B2524-9CE5-486B-B278-F99A8D1CEBDE} {462B805D-D942-4396-B2D3-920B440235FA} 35488 /install /passive /norestart’
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe’
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)'
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_001_Redist_NetCore_WindowsDesktop_Runtime.log’
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleInProgressName’ to value ‘’
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleName’ to value ‘Microsoft Windows Desktop Runtime 10.0.2 (x64)’
[89FC:2FDC][2026-06-18T12:52:11]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Microsoft Corporation’
[89FC:74F8][2026-06-18T12:52:12]i000: Ignoring unknown argument: /install
[89FC:74F8][2026-06-18T12:52:12]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘5.0.2.3’
[89FC:74F8][2026-06-18T12:52:12]i000: Setting numeric variable ‘WixStdBASuppressOptionsUI’ to value 1
[89FC:74F8][2026-06-18T12:52:12]i000: Setting numeric variable ‘WixStdBAShowVersion’ to value 1
[89FC:74F8][2026-06-18T12:52:12]i000: Setting numeric variable ‘WixStdBALanguageId’ to value 2052
[89FC:2FDC][2026-06-18T12:52:12]i100: Detect begin, 4 packages
[89FC:2FDC][2026-06-18T12:52:12]i000: Registry value not found. Key = ‘SOFTWARE\dotnet\Setup\InstalledVersions\x64’, Value = ‘InstallLocation’
[89FC:2FDC][2026-06-18T12:52:12]i000: Setting numeric variable ‘DotnetInstallLocationExists_x64’ to value 0
[89FC:2FDC][2026-06-18T12:52:12]i000: Registry key not found. Key = ‘SOFTWARE\dotnet\Setup\InstalledVersions\x86’
[89FC:2FDC][2026-06-18T12:52:12]i000: Setting numeric variable ‘DotnetInstallLocationExists_x86’ to value 0
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘DotnetInstallLocationExists_x64’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘NOT DotnetInstallLocationExists_x64 AND NOT NativeMachine=“x64”’ evaluates to true.
[89FC:2FDC][2026-06-18T12:52:12]i000: File search: DotnetExeSearch_alt_x64, did not find path: [ProgramFiles64Folder]dotnet\x64\dotnet.exe
[89FC:2FDC][2026-06-18T12:52:12]i000: Setting numeric variable ‘DotnetExeExists_alt_x64’ to value 0
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘DotnetExeExists_alt_x64’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘NOT DotnetInstallLocationExists_x64 AND (NOT NativeMachine OR NativeMachine=“x64”)’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘DotnetExeExists_x64’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘DotnetInstallLocationExists_x86’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘NOT DotnetInstallLocationExists_x86’ evaluates to true.
[89FC:2FDC][2026-06-18T12:52:12]i000: File search: DotnetExeSearch_x86, did not find path: [ProgramFilesFolder]dotnet\dotnet.exe
[89FC:2FDC][2026-06-18T12:52:12]i000: Setting numeric variable ‘DotnetExeExists_x86’ to value 0
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘DotnetExeExists_x86’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft.NET’
[89FC:2FDC][2026-06-18T12:52:12]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft.NET\10.0’
[89FC:2FDC][2026-06-18T12:52:12]i000: Setting numeric variable ‘RemoveSpecificPreviousVersionRegistryKeyExists’ to value 0
[89FC:2FDC][2026-06-18T12:52:12]i052: Condition ‘RemoveSpecificPreviousVersionRegistryKeyExists=1’ evaluates to false.
[89FC:2FDC][2026-06-18T12:52:12]i110: Detected bundle provider key: {90d77843-5fbd-64ef-6bdf-df7574d01646} that is registered to a different bundle: {0B1257AA-9D34-46E7-B27B-07DF8CD5B92C}
[89FC:2FDC][2026-06-18T12:52:12]i107: Detected forward compatible bundle: {0B1257AA-9D34-46E7-B27B-07DF8CD5B92C}, type: Upgrade, scope: PerMachine, version: 10.0.9.50000, cached: Yes
[89FC:2FDC][2026-06-18T12:52:12]i102: Detected related bundle: {0B1257AA-9D34-46E7-B27B-07DF8CD5B92C}, type: Upgrade, scope: PerMachine, version: 10.0.9.50000, cached: Yes
[89FC:74F8][2026-06-18T12:52:12]i000: Related bundle version: 10.0.9.50000 is a downgrade for bundle version: 10.0.2.50000.
[89FC:2FDC][2026-06-18T12:52:12]i103: Detected related package: {1BE0093C-57AD-46B8-9781-8437664E9957}, scope: PerMachine, version: 80.36.53633, language: 1033 operation: Downgrade
[89FC:2FDC][2026-06-18T12:52:12]i108: Detected compatible package: DotNetHost, provider: Dotnet_CLI_SharedHost_10.0_x64, installed: {1BE0093C-57AD-46B8-9781-8437664E9957}, version: 80.36.53633, chained: {454E702A-88DE-4F78-80B0-B1340A4BFB13}
[89FC:2FDC][2026-06-18T12:52:12]i101: Detected package: DotNetHost, state: Obsolete, cached: No, install registration state: Absent, cache registration state: Absent
[89FC:2FDC][2026-06-18T12:52:12]i101: Detected package: DotNetHostFxr, state: Absent, cached: No, install registration state: Absent, cache registration state: Absent
[89FC:2FDC][2026-06-18T12:52:12]i101: Detected package: DotNetRuntime, state: Absent, cached: No, install registration state: Absent, cache registration state: Absent
[89FC:2FDC][2026-06-18T12:52:12]i101: Detected package: WindowsDesktopRuntime, state: Absent, cached: No, install registration state: Absent, cache registration state: Absent
[89FC:74F8][2026-06-18T12:52:12]i000: Setting string variable ‘RemoveUpgradeRelatedBundle’ to value ‘always’
[89FC:74F8][2026-06-18T12:52:12]i052: Condition ‘WixBundleInstalled OR (NOT DOTNETHOME_X64 ~= DOTNETHOME_X86) OR DOTNETHOMESIMILARITYCHECKOVERRIDE’ evaluates to true.
[89FC:74F8][2026-06-18T12:52:12]i052: Condition ‘WixBundleInstalled OR (NOT DOTNETHOME_ARM64 ~= DOTNETHOME_X86) OR DOTNETHOMESIMILARITYCHECKOVERRIDE’ evaluates to true.
[89FC:74F8][2026-06-18T12:52:12]i052: Condition ‘WixBundleInstalled OR (NOT DOTNETHOME_ARM64 ~= DOTNETHOME_X64) OR (NOT NativeMachine=“arm64”) OR DOTNETHOMESIMILARITYCHECKOVERRIDE’ evaluates to true.
[89FC:2FDC][2026-06-18T12:52:12]i199: Detect complete, result: 0x0, registration state: None, cached: No, eligible for cleanup: No
[89FC:2FDC][2026-06-18T12:52:12]i200: Plan begin, 4 packages, action: Install
[89FC:2FDC][2026-06-18T12:52:12]w224: Plan skipped due to related bundle of plan type Downgrade:
[89FC:2FDC][2026-06-18T12:52:12]w225: id: {0B1257AA-9D34-46E7-B27B-07DF8CD5B92C}, version: 10.0.9.50000
[89FC:2FDC][2026-06-18T12:52:12]i299: Plan complete, result: 0x0
[89FC:2FDC][2026-06-18T12:52:12]i300: Apply begin
[89FC:74F8][2026-06-18T12:52:12]i000: Setting string variable ‘WixStdBARestartRequired’ to value ‘’
[89FC:2FDC][2026-06-18T12:52:12]i399: Apply complete, result: 0x80070666, restart: None, ba requested restart: No
[89FC:2FDC][2026-06-18T12:52:12]i500: Shutting down, exit code: 0x666
[89FC:2FDC][2026-06-18T12:52:12]i502: Cleanup begin.
[89FC:2FDC][2026-06-18T12:52:12]i599: Cleanup complete, result: 0x0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: BUNDLEMONIKER = Microsoft Windows Desktop Runtime
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DotnetExeExists_alt_x64 = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DotnetExeExists_x86 = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DOTNETHOME =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DOTNETHOMESIMILARITYCHECKOVERRIDE =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DotnetInstallLocationExists_x64 = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DotnetInstallLocationExists_x86 = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: DOTNETRUNTIMEVERSION = 10.0.2
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: MINIMUMVSVERSION =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: NativeMachine = 34404
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: ProgramFiles64Folder = C:\Program Files\
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: ProgramFilesFolder = C:\Program Files (x86)\
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: RebootPending = 1
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: RemoveSpecificPreviousVersionRegistryKeyExists = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: RemoveUpgradeRelatedBundle = always
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: VERSIONMAJOR = 10
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: VERSIONMINOR = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleAction = 6
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleCommandLineAction = 6
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleElevated = 1
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleFileVersion = 5.0.2.3
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleInProgressName =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleInstalled = 0
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleLog = C:\Users\AHTSPE~1\AppData\Local\Temp\Rhino_WIP_20260618125119_001_Redist_NetCore_WindowsDesktop_Runtime.log
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleManufacturer = Microsoft Corporation
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleName = Microsoft Windows Desktop Runtime 10.0.2 (x64)
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleOriginalSource = C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\windowsdesktop-runtime-10.0.2-win-x64.exe
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleOriginalSourceFolder = C:\ProgramData\Package Cache\Microsoft Windows Desktop Runtime - 10.0.2 (x64)\
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleProviderKey = {90d77843-5fbd-64ef-6bdf-df7574d01646}
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleTag =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleUILevel = 1
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixBundleVersion = 10.0.2.50000
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixStdBALanguageId = 2052
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixStdBARestartRequired =
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixStdBAShowVersion = 1
[89FC:2FDC][2026-06-18T12:52:12]i410: Variable: WixStdBASuppressOptionsUI = 1
[89FC:2FDC][2026-06-18T12:52:12]i007: Exit code: 0x666, restarting: No
Rhino WIP 的安装需要 Rhino 8 的授权, 请私信回复一下你的 Rhino 8 授权码, 谢谢
