Rhino 7.19 (SR19) 发布更新,所有 Rhino 7 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包 - 下载离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可
链接: 百度网盘 请输入提取码 提取码: 3f78
在 Rhino 7.19 中修复了以下的错误
- BlendSrf: Problem about interior shapes (RH-68315)
- FilletEdge: Preview display performance dropped significantly (RH-68394 )
- Isolate: Opened the selection filter (RH-68303)
- Join: RhinoJoinBreps produced an odd result (RH-68363)
- PackageManager: Older public GH2 version installed over newer private GH2 version (RH-68355)
- Panels: Divider panel style did not allow overriding (RH-68508)
- RDK: Wireframe post effects did not work with RenderWindow and RenderInWindow (RH-67382)
- Rendering: Cycles:
- Rendering: Materials: Replacing a PBR material of a layer with another PBR material failed (RH-68543)
- SDK: Divider did not work in vertical orientation (RH-68546)
- SDK: RhinoCommon: Intersection.CurveLine returned all wrong ParameterB values (RH-68486 )
- Sweep2: Regression between 7.13 and 7.14 (RH-68379 )
- Trim: Non-trimmable lines selected by SelBrush or SelFence causing infinite loop (RH-68721)
已经修复的宕机错误如下:
改进内容与新增特征如下:
开发工具改进内容
仅 Mac 版 Rhino 调整内容
仅 Windows 版 Rhino 调整内容
