Rhino 7.20 (SR20) 发布更新,所有 Rhino 7 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包 - 下载离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可
链接: 百度网盘 请输入提取码 提取码: cc1j
在 Rhino 7.20 中修复了以下的错误
- DimArea: Reported a negative value in a specific case (RH-68956)
- ExtractSubCrv: Reported too many messages in command-line history (RH-68919)
- Gumball: Extrude handles did not show for sub-objects until Reflect was updated or removed (RH-68603)
- GumballAlignment: Default did not update (RH-68735)
- Lights: Dragging intensity spinner and releasing left mouse button on color box incorrectly popped up select color dialog (RH-68625)
- Match: Curvature continuity changed wrong end of curve (RH-68826 )
- NamedSelections: Adding selection sets did not trigger saving file prompt if no other changes were made in the model (RH-68727)
- Picture: Displayed the old bitmap even after deleted (RH-68637)
- Rendering: Cycles Viewport: Skylight did not properly turn off (RH-69072 )
- Scale1D: Scaling block insertion points incorrectly scaled block geometries (RH-64983)
- Surface-surface intersection: Overlapping detection was much slower in V7 (RH-68720 )
- ToNURBS: Failed when SubD faces exceeded 30k (RH-62025 )
- Undo: Only one Undo was possible if Max undo memory was set to 4096 MB (RH-47940)
宕机修复
- Layout: Right-clicking a field in the Layouts panel caused a crash (RH-68840)
- SDK: RhinoCommon: Intersections.CurveLine sometimes returned null (RH-69329)
开发工具SDK增强
计划任务达成
- RPC: Plug-in is removed from Rhino installer (available for download from Package Manager) (RH-69251 )
仅 Rhino Mac 版本的调整内容
错误修复:
仅 Rhino Windows 版的调整内容
错误修复:
