Rhino 8.11 (SR11)
Rhino 8.11 (SR11) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 点击这里进入百度网盘下载
链接: 点击这里进入百度网盘下载
- Don’t make Selected Objects Only hide multiple layout controls (RH-83536)
- rint: Image resolution presets not saving/restoring correctly (RH-83254)
- Annotation: Linetype: Added search box to linetype import dialogs (RH-82978)
- CPlane: AutoAlign: Auto CPlane won’t align to planar face (RH-83499)
- Cage: CageEdit on particular curves not working (RH-83497)
- ClippingDrawings: Block sectioning is broken (RH-83197)
- ClippingPlane: Clipping Plane creates havoc (RH-82726)
- Commands: Pressing Enter does not repeat Snap command (RH-82789)
- CopyLayout: CopyLayout to Keep Original Layer Visibility Settings (RH-83485)
- Crash: Wireframe geometry crashes ARM Windows Computers (RH-83663)
- CrvDeviation:
- Detail: Detail View Panel display mode setter fires incorrectly (RH-83673)
- Displacement: Mesh update incomplete in Technical display mode (RH-82499)
- Display:
- Text Drawing Incorrect For OratorStd Font (RH-45774)
- UndoView on a detail view while PrintDisplay is ON creates a mess (RH-83187)
- Low speed for blocks in Rhino 8 in Ghosted mode (RH-83267)
- SubD boundaries in flat mode do not display locked color (RH-80965)
- Zooming into a layout view causes slowdown… (RH-83121)
- Ghosted mode is about 40% slower on the Mac (RH-83065)
- File IO:
- Grasshopper: Components:
- Gumball:
- Intersect: Fails with a case of two surfaces (RH-82922)
- Keyboard Shortcuts: Proposal for adding commands to keyboard shortcuts. (RH-79531)
- Layer:
- Layout: Geometry disappears in detail view (RH-83587)
- OffsetCrvOnSrf: Trims incorrectly (RH-83206)
- Options: OpenGL.WireThicknessScale in Advanced settings shows too many decimals (RH-45405)
- Print:
- Print widths don’t work correctly for dimensions (RH-83328)
- Vector: Occlude PointClouds (RH-83567)
- Rhino PDF fails to print (RH-81691)
- Vector: Section Hatches not Clipped (RH-82141)
- some special characters display but do not print (RH-68835)
- Vector Output Shifts Centered and Right Justified Text (RH-64543)
- RhinoPDF Printing Text with Bahnschrift Font Incorrectly (RH-64213)
- Text offset in PDF print (RH-47886)
- Unicode symbols lost in vector output (RH-65395)
- Failure to create PDF with Ubuntu font (RH-44699)
- Added TestSavePdfTo3dmPath command for saving PDF to 3dm path (RH-83225)
- QuadRemesh:
- Rebuild: Polysurface faces incorrectly being pickable (RH-83079)
- Rendering: Cycles: Focal blur works in Parallel view but no controls are available (RH-82715)
- Rendering: Materials:
- Rendering: Post Effect:
- Rendering: Textures: Edit button should be more clear (RH-82521)
- SDK: GhPython: clr.AddReference(“GhPython”) fails in Rhino > 8.3 (RH-83122)
- SDK: RhinoCommon: Curve.ExtendOnSurface method crashes Rhino.Compute (RH-83304)
- ScriptEditor:
- Adding IronPython to project still uses python 3 (RH-83675)
- Rhino Obj to Guid converter on script component does not work (RH-83704)
- Script doesn’t work when run as python 3 (RH-83002)
- Editor mangles script when it is updated during debug (RH-83287)
- Scripts with async specifier do not run async outside of editor (RH-83097)
- Disable other editors when one is in debug (RH-82512)
- C# Debugger breaks on lambda style function body (RH-83216)
- Adding inputs on component fails when RunScript is multiline (RH-83124)
- Published GH1 command does not clear contextual data consistently (RH-83231)
- RunScript parameter named outline automatically turns into output (RH-83087)
- Published components do not show icon on Rhino 7 (RH-81170)
- SetPt: Surface to Z is not flat (RH-82835)
- Snapshot: Screenshot: Restore called through SDK does not work properly (RH-83172)
- StatusBar:
- Sun: Map and city list do not select initial city (RH-82786)
- TextField: 8.10 breaks empty values in BlockAttributeText (RH-83491)
- TweenSurfaces: TweenSurface: Display refresh issue (RH-82782)
- UDT:
- Undo: Fails with renaming grouped lights (RH-83064)
界面调整
- UI Cleanup: ReduceMesh command dialog not theme aware (RH-83266)
- BlockEdit: Forbid commands of section tools when editing an embedded block (RH-71830)
- Grasshopper: Components: Misspelling of Deconstruct in Component (RH-83484)
- Rendering: Content Panels: Added Back and Forward buttons back to Materials, Environments, Textures panels (RH-82522)
- Toolbar: Cascade triangles are heavy (RH-79275)
- ViewPropertiesPage: Removed “Pick” button from Focal Blur settings of parallel views (RH-83158)
宕机修复
- Properties: Crash When Changing Arrow Style (RH-83599)
- Rendering: Risky Action [<.ctor>g__RunGuarded|1] System.InvalidOperationException: Sequence contains no elements (RH-82298)
增强内容
- Annotation: Hatch: Improve performance of loading hatch thumbs in dropdowns (RH-83017)
- Annotation: Linetype: Added search box to Document Properties > Linetypes (RH-83008)
- Block: Exploding blocks keeps groups (RH-83029)
- BooleanUnion: Added MergeCoplanarFaces=Yes/No option (RH-83171)
- Code Editor Control: Added Setting to add/remove indentation guides (RH-82613)
- File IO:
- Grasshopper:
- Installer: Insntaller: Provide a URL to query for latest rhino installer (RH-80327)
- Layer: Add Expand and Collapse options to -Layer command (RH-83351)
- Rendering: Sun settings use current local date and time by default (RH-80940)
- Rendering: Texture Mapping: Added SetMeshSurfaceParameters command to avoid losing UVs on squish mesh (RH-80911)
- SVG Editor: : Cannot save to PNG (RH-82532)
- ScriptEditor: Implement Save As for projects (RH-75462)
- Section Tools: Added “from” option to PlacementPoint option of EditClippingDrawings command for precise placement (RH-83161)
- Toolbar: Allows selecting which rhi file to add new toolbar (RH-81286)
- UserText: Paste key and value to all → Make context aware (RH-62668)
- WindowLayout: Scriptable WindowLayout command need “Import” option (RH-83468)
增加特征
- Grasshopper:
- Rendering: Texture Mapping: New SetMeshSurfaceParameters command (RH-66671)
- SVG Editor:
- ScriptEditor: Support other filetypes in the editor (RH-81609)
- Section Tools: Added DisplayColor=ByLayer/ByInputObject option to ClippingDrawings and EditClippingDrawings commands (RH-83145)
性能改善
- Display: Lagging with Many Curves (RH-82891)
- ExtendSrf: ExtendSrf removes trims (RH-83317)
- MergeAllCoplanarFaces: Creates invalid Brep (RH-82695)
- MergeAllEdges: Creates invalid Brep (RH-82696)
- Print: Detail Print Width Not being printed or modified (RH-83487)
- Rendering: Textures: Dots texture pattern discontinuity (RH-82644)
- ScriptEditor:
- Tab Constraint: Lock is Broken (RH-83670)
开发工具增强
- OpenNURBS: Added C++ ON_Integrate() tools for integrating 1 and 2 variable functions (RH-83256)
- SDK: RhinoCommon:
- Expose ON_SubD::TransformComponents to RhinoCommon (RH-83674)
- Added Shadow and Grid display properties (RH-83215)
- Provide a public constructor for ClippingPlaneSurface type (RH-83213)
- Provide ExtractControlPolygon functonality (RH-83271)
- Added Object display properties (RH-83136)
- Added Light and Clipping Plane Display Properties to .Net SDK (RH-83095)
适用性问题修复
- Panels: “One Click” Show Panels (RH-74338)
- ScriptEditor:
- Improve stdout handling (RH-77370)
- : Project author editing does not update (RH-75881)
- Added option to “Run Without Debugging” (RH-82713)
- Allow multiple scripts to be added to a project to compile into a plug-in (RH-80870)
- Support default icons for published components (RH-81169)
- Allows building project from rhinocode CLI (RH-75546)
- Improved error reporting on the publish plugin window (RH-77167)
- StatusBar: Improving coordinates readability (RH-79957)
Mac 版相关内容
- Display:
- Display Metal: Pointcloud display style on Mac doesn’t work. (RH-83416)
- Grasshopper:
- Options: Mouse option out of sync with corresponding advanced settings (RH-42536)
- SDK: Bella plug-in fails to load in 8SRC11 ([RH-83330]chuang(https://mcneel.myjetbrains.com/youtrack/issue/RH-83330))
- UI Appearance: Coordinates in statusbar update slowly (RH-77199)
❖ Windows 版相关内容
- Display:
- DotNET: Support running on later versions of .NET (RH-81818)
- Layout:
- Print:
- ScriptEditor: Loading exception error (RH-83162)
性能改善
- Display: Slow performance drawing lots of curves (RH-80310)
- Display: Custom material with env map created in Rhino 7 loads incorrectly in Rhino 8 Rendered mode (RH-82896)
- Print: Leader with Japanese text Not Printing with V8 RhinoPDF (RH-79834)
SDK 增强
- SDK: Expose function behind ParseTextField to C++ SDK (RH-83723)
