Rhino 8.18 (SR18)
Rhino 8.18 (SR18) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- Not possible to add decal via code (RH-71351)
- Annotation: DimLinear: Dimensions moving when going from layout to detail (RH-71948)
- BlendSrf: Doesn’t update cleanly with History (RH-35903)
- BlockEdit: Block instance not immediately updating after transform change in UI (RH-86090)
- BlockManager: Does not allow renaming by changing case of letters (RH-86186)
- BoxEdit: Viewport Lag after selection (RH-85982)
- Code Editor Control: Add Ctrl + / shortcut to comment out (RH-79802)
- Containers: Exporting container adds an extra “.rhc” to file name (RH-86203)
- Displacement: Does not use Object Properties repeat values correctly (RH-85943)
- Display:
- Hidden Line Width is Capped (RH-86491)
- No BlendCrv Preview in Selectively Clipped Scene (RH-86148)
- Selecting objects in Rendered mode is only showing naked edges (RH-86110)
- “Use advanced GPU lighting” setting causes blackout when shadows are off (RH-86353)
- Gumball Block Copy with Sun Weirdness (RH-86034)
- ExtractClippingSections: Extract Clipping Sections / Slices from hidden objects (RH-85941)
- File IO: Physically Based Materials incorrectly export to OBJ (RH-84157)
- FilletEdge:
- Grasshopper:
- Grasshopper: Components: Model Object (Object) component not working on Mac (RH-86533)
- History: MatchSrf/BlendSrf issue with FilletEdge Edit (RH-86285)
- Layer:
- Layout: Dimensions get misaligned when scaling a layout (RH-72038)
- Make2D:
- Match: Not working as intended when curvature of curve to match is zero (RH-86253)
- MatchSrf: Matched surface with History gets distorted when trimmed (RH-62959)
- OpenNURBS: Heap corruption error reading V2 file (RH-83540)
- OSnap: No Snap to Feature Close to Detail Border (RH-86313)
- PluginManager: UI is loading wrong plug-in assembly (RH-86326)
- Print: Fake2D Does Not Print Inner Border of Hatch (RH-85634)
- RDK:
- Rendering: Cycles renders invisible decals (RH-86069)
- Rendering: Textures: Rhino 8 duplicates embedded_files folder (RH-86235)
- ScriptEditor:
- env flag stopped working (RH-86665)
- Python completion accidentally executes code (RH-86612)
- Color input conflicts with Eto.Drawing.Color (RH-86380)
- Python component does not include error line (RH-86122)
- String return from RunScript is treated as enumerable in Python 2 (RH-86400)
- Value Type Hints always provide a value (RH-86354)
- Required ref to RhinoCodePlugin (RH-86357)
- Torch-scatter fails to install (RH-86073)
- Two Project components in Grasshopper collide in NodeInCode (RH-85684)
- ClippingBox does not work as property getter (RH-86112)
- Some help entries end in forward slash (RH-86151)
- Completion fails for specific script in any python (RH-86072)
- SDK: RhinoCommon:
- Section Tools: Clipping drawing background for mesh is misaligned (RH-84452)
- SVG Editor:
- Templates: Small Objects - Inches template has unhelpful defaults (RH-85365)
- TextObject: Center for text is not the same as Gumball center (RH-85952)
- Toolbar: Button image gets blurry when copied from Rhino 8 to Rhino 7 toolbar (RH-86056)
- UVEditor: Added “Selection from model” button (RH-84044)
- ViewCaptureToFile: Forces saving transparent background if it is set in display mode (RH-42925)
宕机错误修复
- Crash: Mesh Boolean Operation Crash (RH-86059)
- FilletSrfToRail: Crash (RH-86202)
- NetworkSrf: Limits input to 20,000 curves to prevent running out of memory (RH-86012)
- Properties: Crash When Placing Wallpaper (RH-86141)
增强内容
- OSnap: Check DrawOrder for Occlusion (RH-86388)
- Display: Color artifacts in blocks (RH-86448)
- Display Metal: Choose One Object does not highlight NURBS objects (RH-86697)
- Grasshopper:
- ScriptEditor: Grasshopper command with ‘keep open’ draws previews always (RH-86267)
开发工具增强
- ScriptEditor:
- SDK: RhinoCommon: Exposed ON_SubD::HasPerFaceColors (RH-86308)
适应性问题修复
- ScriptEditor: Print-Line-By-Line by default (RH-86071)
仅 Mac 相关内容调整
- CommandHistory: Opens and ends up empty (RH-83932)
- Containers: Scrolling toolbars on Mac does not work well (RH-81700)
- Display:
- DocumentProperties: Render settings edit dialog for contents are not the topmost window (RH-84585)
- Grasshopper: Opening user cluster on Mac causes graphics pipeline error (RH-84901)
- Layout: No Fly-out Case (RH-86312)
- Weight: Values are Rounded to 3 Decimal Places (RH-86444)
- Display: Arctic Mode Doesn’t Show Arrowheads in Parallel Views (RH-86209)
- Settings: Restore Defaults does not work for Appearance (RH-84981)
- Sidebars: Collapse Regression (RH-86173)
适用性问题修复
- Grasshopper: Shift-enter/return shortcut in Edit Notes panel inserts extra line (RH-77350)
❖ 仅 Windows 版调整内容
- Annotation: Dimension Shift With Detail Window Activation/Deactivation (RH-65652)
- Display: Surface and SubD settings don’t indicate overrides (RH-73167)
- SDK: C++ SDK plug-in wizard produces incorrect stdafx.h (RH-81812)
- Turntable: Does not remember the previous value in localized versions (RH-86500)
- UI Appearance: Lots of extra windows visible when pressing Alt+Tab (RH-85630)
宕机修复
- File IO: Exporting 3mf file crashes rhino (RH-86784)
开发工具增强
- SDK: Added Window Layout support to Rhino C++ SDK (RH-86304)
适用性问题修复
- ScriptEditor: Font variations does not work in new script editor (RH-78080)
Rhino 8.18 SR18 HotFix 1 修复
- Linetype: Model Space Scaling in Detail is Busted (RH-86973)
