Rhino 8.19 (SR19)
Rhino 8.19 (SR19) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- Annotation: Hatch: ‘Match’ button in Hatch creation and properties differs (RH-86399)
- Contour: History children don’t allow layer changes (RH-79631)
- CPlane: AutoAlign: AutoCplane + Universal Construction Planes + toggling snaps jumps plane around in views (RH-86535)
- Developer Tools: Add .NET 7 target to nuget package(s) (RH-77311)
- Display: Turning ground plane off clips shadows (RH-87153)
- DocumentProperties: Environment scripting doesn’t work (RH-86798)
- Emap: EMap: Doesn’t Work With PBR Materials (RH-86871)
- Eto: Rhino and grasshopper windows minimize when Script Editor is closed (RH-78793)
- File IO:
- Grasshopper: Bake Should Use Model Space Scaling (RH-85976)
- Gumball:
- History:
- Layer: Duplicate Layer missing persistent settings (RH-86817)
- Linetype: Width units not sticking (RH-86626)
- Make2D:
- MatchAnnotation: Does not change font styles (RH-86761)
- MergeAllEdges: Failure Case (RH-86490)
- Mesh: PackTexture not working in v8 (RH-86277)
- OneView: Does not work with SpaceMouse (RH-67401)
- Print:
- Rendering: Decals: Adding decal and switching to Raytraced mode can cause crash (RH-87143)
- Rendering: Realtime SDK: Don’t trigger Raytraced restart on unimpactful changes (RH-86898)
- Rendering: Textures: Reading texture errors require force-quit (RH-86316)
- ScriptEditor:
- Compas version comparison keeps reinstalling package (RH-86793)
- stackalloc is before static in suggestions (RH-86742)
- Method input args do not show up on suggestion list (RH-86741)
- Extension methods are missing in completion (RH-86744)
- ReferenceEquals is missing in completion (RH-86740)
- DimensionStyle does not have TextAlignment (RH-86539)
- SDK: Brep.CreateTrimmedSurface only uses face[0] as trimSource (RH-86795)
- SelAll: Objects hidden in active detail view incorrectly selected in other detail views (RH-86881)
- Selection:
- SubD: eflect: Hang on Join with this file (RH-86811)
增强内容
- File IO: Use filename for single layout print name when TestSavePdfTo3dmPath is enabled (RH-86690)
- MatchProperties: Now works with hatches when other object types are selected together (RH-86851)
- OSnap:Cen: OSnap Cen: Supports snapping to center of Extrusion faces with a polyline profile (RH-86763)
- ScriptEditor:
- SelectionFilter: Added ‘RepeatDisableCount’ advanced setting to prevent selection filters from being disabled by failed picking attempts (RH-86821)
- Sweep2: Only allows double-click chaining when ChainEdges is enabled (RH-85281)
- UserText: Allows copying keys and values to other apps (RH-86891)
- Display: Curves in Blocks invisible when copying (RH-87147)
- Display Metal: Choose One Object does not highlight NURBS objects (RH-86697)
- Grasshopper: Sort list fails (RH-87154)
- PackageManager: Grasshopper fails to find rh7* package (RH-78811)
- Print: Fake2D: Curves are Moved (RH-87169)
- Rendering: Decals: Python script using decal crashes (RH-86760)
- Sun: Settings broken for time/date (RH-86536)
开发工具增强
- SDK: RhinoCommon:
适应性问题修复
- BlockManager: Sorts block definition names in natural sort order (RH-59136)
- Code Editor Control:
- ScriptEditor:
Rhino Mac 相关
- Clipboard: Command+C does not copy file name from title bar on Mac (RH-86543)
- MatchAnnotation: Missing in Rhino 8 for Mac (RH-86815)
- PluginManager: PlugInManager: Tuneups needed on macOS (RH-86171)
- ScriptEditor:
宕机修复
- SVG Editor: Changing Icon causes Crash when Applying in Button Editor (RH-86591)
Rhino Windows 相关
增强内容
- Splash and About: Now shows document icon when thumbnail missing (RH-86736)
性能增强
- Rendering: CPU is still being used after rendering is finished (RH-85569)
开发工具增强
- SDK: RhinoCommon: File3dm.SetPreviewImage should also clear (RH-86735)
