Rhino 8.20 (SR20)
Rhino 8.20 (SR20) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- CPlane: Auto CPlane conflicts with OneView (RH-87056)
- CurveBoolean: Should temporarily disable Grid Snap (RH-87124)
- Display:
- File IO:
- File IO: DWG:
- Groundplane: Cannot automatically update its height in Raytraced display mode (RH-87386)
- Isometric: Causes perspective to go nuclear (RH-87009)
- Layer: Resetting layer filter clears selection (RH-87301)
- Make2D: Fixed a case that v5 works better (RH-53201)
- NamedSelections: Delete UI performance issue (RH-86766)
- OneView: Disable OneView doesn’t allow to set CPlanes (RH-87206)
- Print:
- Properties: Button behind layer dropdown is activated (RH-87230)
- PushPull: Does not work for certain flat surfaces (RH-87208)
- Rendering: Cycles: Picture self-illumination broken (RH-86111)
- Rendering: Materials: Deleting 400 materials takes 4 minutes (RH-87261)
- ScriptEditor:
- SDK: Support plug-in overrides for double click behaviour (RH-87007)
- SDK: RhinoCommon:
- Section Style: Hatches sometimes do not work well (RH-84034)
- StatusBar: Units are wrong (RH-86732)
- Thicken: Mesh settings don’t update thickened mesh (RH-87238)
- UserText: Cannot only paste to key or value column (RH-87263)
- Viewports: Lens length decreases when toggling view projection between Perspective and Parallel (RH-86523)
- What: Shows Text info for Point Clouds (RH-87142)
宕机修复
- File IO: Exporting any mesh as obj crashes (RH-87315)
增强内容
- File IO: Supports reading SolidWorks 2025 files (RH-87219)
- Layer: Allows setting all layer properties (except materials, linetypes, and section styles) of reference layers from linked blocks (RH-68718)
- OSnap:Mid: When only midpoint is enabled, moving mouse cursor near any part of a curve would snap to its midpoint (RH-86927)
- Export: Saving to DXF regression (RH-87322)
- File IO: Export OBJ Crashes (RH-87058)
- Import: No longer process gh files in scripts (RH-87156)
- MeshOutline: Broken in 8.20 (RH-87452)
- Print: Messy Vector Print from Intersecting Objects (RH-86993)
- SDK: RhinoCommon: DisplayPipeline.DrawText regression (RH-87220)
- SpaceMouse: Does not select properly (RH-87017)
开发工具增强
- SDK: RhinoCommon:
适用性修复
- ScriptEditor: Should autocomplete code params (RH-85076)
仅 Rhino Mac 相关
- CommandHistory: Command popover causes wrong document to be key after Cmd + N (RH-83106)
- File IO: DWG: Export incorrectly on Mac (RH-87325)
- Grasshopper: TTToolbox crashes Rhino (RH-87049)
- Gumball: Arrows heads don’t display (RH-87337)
❖ 仅 Rhino Windows 相关
- Analytics: All analysis panels are blank (RH-87637)
- Rendering: Vray rendering of mesh modifiers broke (RH-87529)
- SDK: RhinoScript: SelectLayers Null argument not working in Rhino 8 (RH-87065)
宕机修复
- Annotation: Leader: Crash on creating 17th leader (RH-87550)
- Eto: Window.Opacity clears out background color (RH-87617)
