Rhino 8.21 (SR21)
Rhino 8.21 (SR21) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- Annotation: Styles: Annotation Style: Annotations not updating when Fit Arrow dropdown is changed (RH-87650)
- Block:
- ClippingPlane: Obscure polyline features (RH-83784)
- Display:
- Document UserText: Tab key gets sent to command-line (RH-87722)
- Explode: Ordinate dimension text is exploded with wrong alignment (RH-87657)
- File IO: Models in decimeters export to STP as meters (RH-87469)
- Grasshopper: Preview of Annotation Dot in viewports is not interactive (RH-87428)
- LineTypeDisplay: Size of dots does not match width of segments (RH-86870)
- Make2D: Hidden lines missing (RH-50127)
- MeshSplit: MeshSplit test case (RH-81394)
- OffsetMesh: Incorrect offset direction (RH-87229)
- RDK: Mouse wheel scrolling stuck in Texture Mapping properties (RH-87432)
- ScriptEditor: Roslyn runtime always extracts netfw ref assemblies (RH-87539)
- SDK: RhinoCommon:
- Squish: Deformation CustomC can’t be set (RH-9895)
- StatusBar: Inches are Shown as Feet (RH-87173)
- SVG Editor: Import clears file prematurely (RH-87575)
- ViewCaptureToFile: ViewCapture.CaptureToBitmap captures with small border (RH-87393)
增强内容
- Block: Added AllBlockInstances option to AddMissingBlockAttributeKeys command (RH-87487)
- PropertiesPage: AlwaysShowGeneralObjectProperties Setting (RH-86628)
- BackgroundBitmap: .pcx format not supported (RH-87433)
- OffsetCrvOnSrf: Does not extend if the surface is trimmed (RH-84888)
开发工具增强
- SDK: RhinoCommon: Exposed CDisplayAttributeMaterial properties (RH-87592)
界面调整
- Units: Renamed ‘Units per meter’ to ‘Meters per Custom Unit’ in document properties (RH-87565)
仅仅 Mac 相关内容
- ChangeLayer: Layer: Crv Points Issue on Locked Layers (RH-87446)
- Linetype: Change Doesn’t Stick (RH-87598)
- MatchSrf: Settings need to use point as decimal separator when comma is set for system (RH-87342)
- PrintPreview: Raster Preview Not Showing Contents of Details (RH-86271)
- Properties: Pressing Enter after changing object properties doesn’t bring focus back to command-line (RH-87366)
宕机修复
- Grasshopper: Crash When Copy String to Clipboard (RH-87235)
- Display: Render mesh broke for some mac users in 8.20 (RH-87449)
- Intersect: Only part of a circle is created between two intersected spheres (RH-87538)
❖ 仅 Windows 版相关
- PrintPreview: Detail Contents Previewed Too Thin as Raster (RH-86273)
- SDK: Removing unimplemented CRhinoDib::ToON_WindowsBitmap (RH-87563)
- SVG Editor: File > Close does not close SVG Editor (RH-87557)
宕机修复
- Display: Turning Off Clipping Plane Crashes (RH-87801)
