Rhino 8.22 (SR22)
Rhino 8.22 (SR22) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- Annotation: DimAngular: Fails in Ortho View (RH-87736)
- Annotation: DimLinear: “Object” Only Dims a Segment (RH-88092)
- Annotation: Hatch: Boundary mode causes history update bug and memory leak (RH-87915)
- ContinueCurve: Resulting curve fails with area calculation (RH-87917)
- Developer Tools: Some RhinoCommon targets should be in buildTransitive in nuget packages (RH-87473)
- Display:
- Extend: Extended Line is Segmented (RH-88091)
- Import: Attributes in DWG Import Incorrectly (RH-87836)
- Layer: Canceling search in Layers panel expands layers (RH-80834)
- PackageManager: Yak CLI uses the wrong install directory on Mac (RH-88110)
- Print: Pring: Incorrect Print Scale Presets Being Resolved (RH-88107)
- Properties: Layer dropdown cannot expand or collapse branches (RH-88246)
- SDK: RhinoCommon:
- OpenNURBS: opennurbs_extensions.cs: Potential bug in ReadApplicationData method (RH-87994)
- OpenNURBS: opennurbs_bezier.cs: GetBoundingBox accurate parameter ignored (RH-87942)
- OpenNURBS: opennurbs_dimension.cs: AdjustFromPoints overload ignores rotationInPlane (RH-87973)
- OpenNURBS: opennurbs_3dm_settings.cs: AnimationName and HtmlFileName properties are nearly identical (RH-87936)
- OpenNURBS: opennurbs_3dm_settings.cs: ModelLocationIsSet returns value base on EarthLocation (RH-87935)
- OpenNURBS: opennurbs_3dm_settings PageAbsoluteTolerance setter sets relative tolerance (RH-87934)
- OpenNURBS: opennurbs_arc.cs Angle property summary is potentially misleading (RH-87940)
- OrdinateDimension.LeaderPoint Bug (RH-87909)
- Selection:
- StatusBar: Changing layer also clicks on panel behind (RH-87718)
- Templates: Thumbnail missing for Small Objects - Inches (RH-88043)
- Trim: Grouped objects on hidden or locked layers can still trim objects (RH-88141)
- WindowLayout: Rhino does not restore the modified layout (RH-78940)
宕机错误修复
- Toolbar: Crash when creating a button (RH-88056)
增强内容
- Grasshopper: Loft & Extrude Point issues (RH-85485)
- Layout: Allows 3 decimals in width and height (RH-87871)
- SelChain: Prefers segments of the same type (curve or edge) as the first picked segment (RH-88270)
- Properties: Layer dropdown loses focus when resized (RH-88003)
界面调整
- Toolbar: Added Grasshopper help button to Grasshopper toolbar (RH-87327)
仅 Mac 版调整内容
- RDKCrash: Crash after internal Metal error (RH-78648)
