Rhino 8.24 SR24 发布更新
:rhinoceros: Rhino 8.24 (SR24)
Rhino 8.24 (SR24) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
  1. 请浏览这里 :point_left:,输入你的Rhino账号绑定的邮箱地址,下载更新安装包;
  2. 下载离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 链接: 点击这里进入百度网盘下载
  1. Rhino Mac 下载后直接运行安装程序即可;
:green_apple: 链接: 点击这里进入百度网盘下载
:cross_mark_button: 错误修复
  • Annotation: DimLinear: DimAligned / Dim shifts after changing properties (RH-89220)
  • Annotation: Hatch: Overwriting existing pattern does not update in viewports (RH-88326)
  • BlendSrf:
    • Does not work consistently (RH-89040)
    • Switching on/off internal shapes makes sliver surface (RH-89109)
  • Display:
    • No Dynamic BoundingBox in Rendered mode (RH-89188)
    • Poorly Visible Curves on Zero-Depth ClippingPlane (RH-83623)
  • ExtendSrf: ExtendSrf_old behaves differently (RH-89006)
  • Grasshopper:
    • Extremes (curve) component doesn’t seem to work right (RH-74711)
    • Pull component should return curve list (RH-89114)
    • Arrow Settings do not get properly serialized/deserialized in GHData In/Out (RH-88819)
    • BoundingBox too small (RH-88798)
  • History: History replay of dimensions when extrusion turns into brep (RH-89215)
  • InsertEdge: Fails to update Radiate symmetry (RH-82094)
  • Join: Extreme slowness caused by unnecessary brep duplications when fixing bad objects (RH-89254)
  • Linetype: Importing line weights makes Rhino crash (RH-88982)
  • Revolve: Deformable=Yes creates rotated output (RH-88979)
  • Ribbon: Makes bad geometry (RH-89031)
  • ScriptEditor: Code close does not save to existing storage (RH-89314)
  • Selection: Weird left-click behavior on Mac (previously clicked items remain selected) (RH-89120)
  • Undo: Curve points are deselected after undoing a move (RH-88900)
:no_entry: 宕机修复
  • Grasshopper: Offset Loose component crashes Rhino when connecting Invalid curve (RH-88858)
  • RDKCrash: Content Instance Browser dialog crashes (RH-88897)
:rocket: 增强内容
  • HighlightObjectLayers: Should open Layers panel (RH-89079)
  • LayerStateManager: User confused on ability to exchange layer states between files (RH-89284)
:multiply: 重现错误修复
  • BlendSrf: Blendsrf failing in v8 and v9, but works in v7 (RH-89796)
  • ScriptEditor:
    • Templates in GH Script do not work and leave script in Readonly (RH-88285)
    • Undo Redo does not work after Replace (RH-89117)
  • SelBoundary: Takes too long to finish (RH-89029)
  • UVEditor: Added back ability of copying UV meshes to clipboard (RH-83978)
:hammer_and_pick: 开发工具增强
  • SDK: RhinoCommon:
    • Exposed CRhinoGet::IsValidOptionName (RH-89300)
    • Exposed MakeUniform command (RH-89160)
:artist_palette: 界面调整
  • Grasshopper: SubD turns null when opened in Rhino 7 (RH-88081)
:green_apple: 仅 Mac 版相关
  • Annotation: Hatch: Gradient hatch handle not visible (RH-87649)
  • PackageManager: PackageManager install dialog not showing buttons on Mac (RH-89655)
  • Properties: Object’s Layer Color is Confused (RH-89712)
❖ 仅 Windows 版相关
  • Rhino Inside: Rhino running headless displays popup about missing fonts (RH-89162)
