Rhino 8.25 (SR25)
Rhino 8.25 (SR25) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- Aliases: Mac/Window alias settings are saved in different locations.. (RH-89588)
- Block: Scaling When Inserted in Detail (RH-89470)
- BlockEdit: Do not repeat hidden commands in its dialog (RH-89760)
- Contour: Inconsistent direction of output curves (RH-89376)
- Displacement: Runs over and over (RH-88735)
- Display:
- Grasshopper:
- Import: Suppress package manager dialog (RH-89710)
- Layer:
- LayerStateManager: Incorrectly Restores Model On State (RH-89486)
- Offset: Incorrect result for self-intersected region (RH-89462)
- OSnap: Cannot snap to selected blocks behind shaded objects (RH-89451)
- Print: Scale of section boundary ignored by vector output (RH-80415)
- Properties: Changing per-face colors overwrites the object’s name (RH-89667)
- Rendering: Materials: FBX Import Change (RH-89515)
- ScriptEditor:
- SDK: Annotation dots near failing intersection (RH-84286)
- SDK: Python: rs.PopupMenu error (RH-86577)
- Selection: Clipping planes can be selected and snapped in display modes that do not display them (RH-89464)
- ShadeSelected: View manipulation cancels object shading (RH-89463)
- ShowEdges:
- Smooth: Needs to remember the dialog location (RH-89645)
- Text: Improving offset for bottom part of fraction stack (RH-81827)
- TextField: PageNumber in model viewports now returns 0 (RH-89428)
- Toolbar:
宕机修复
- Options: Custom display model with “%” in the name crashes Rhino (RH-89844)
增强内容
- Bake: Added FillRange option for post-selection (RH-89677)
- EdgeSoftening: Allows more decimals (RH-89753)
性能改善
- Grasshopper: Slow down material assignment (RH-89738)
- BoundingBox: Extrusion Bounding Box behaviour different in Rhino 7 and Rhino 8 (RH-89799)
开发工具增强
- SDK:
- SDK: RhinoCommon: Added a new Curve.TrimInterval which calls ON_Curve::Trim like Rhino_DotNet (RH-89686)
仅 Mac Rhino 相关内容
- Eto: FileDialog crashes when specifying all files (RH-90064)
- PackageManager: Install dialog not showing buttons on Mac (RH-89655)
- Properties: Can’t change layer of multiple objects at once on Mac (RH-89614)
- Quicklook: Thumbnail previews not working on macOS Tahoe (RH-90113)
- RhinoMonitor: Error report window drifts off screen while resizing (RH-89691)
- SDK: RhinoCommon: CommandWindowCaptureEnabled not working on macOS (RH-89365)
❖ 仅 Windows Rhino 相关内容
- Print: Printing multiple layouts to images fails (RH-89708)
- Toolbar: Loading RUI locks up Rhino (RH-89475)
增强内容
- CommandPaste: Supports pasting AutoCAD LT data from clipboard into Rhino (RH-90097)
