Rhino 8.26 (SR26)
Rhino 8.26 (SR26) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- Annotation: Hatch:
- BlockEdit: Unlock and BlockEdit (RH-52030)
- Containers: Collapsed Properties Panel Blocks Access to Rhino (RH-82645)
- CPlane: AutoAlign: Hangs Rhino when sub-selecting many mesh faces (RH-90290)
- Grasshopper:
- Grasshopper: Components: Grasshopper: Rhino 8 GH Extreme component bug (RH-90027)
- HeightField: Mesh output does not respect active layer (RH-90052)
- Keyboard Shortcuts: “⌘ + /” Hotkey Keybinding doesn’t save (RH-90304)
- Layer: Restore Print color doesn’t restore synchronization (RH-90172)
- MeshIntersect:
- Print: Intersections repeatedly added cause printing to freeze (RH-89973)
- RDK: CRhRdkLongOperation messes up cursor settings (RH-90237)
- ScriptEditor: Python 3 seems to fail sometimes on matplotlib bootstrap script (RH-90171)
- SDK: RhinoCommon: InstanceObject.UsesDefinition returns false positives (RH-90174)
- SelVisible: No Hatch Support (RH-90294)
- UserText: Ensure document user text with an empty value won’t be deleted (RH-90302)
宕机修复
- Grasshopper: Rhino crashes in 8.25 with a specific gh file (RH-90835)
性能改善
- Display: Lagging with Many Curves (RH-82891)
- Grasshopper: Sweep1 Different in SR25 or later (RH-90489)
- Properties: Cannot type to find a layer in object properties (RH-89948)
Mac 版相关
- BlendEdge: Edit BlendEdge set to 0 oblitterates Object (RH-90029)
- Display: Rendered mode on Mac ignores transparent objects shadow tolerance (RH-89935)
❖ Windows 版相关
- ModifyRadius: Does not accept Enter to keep radius and end command on Windows (RH-90059)
