Rhino 8.27 (SR27)
Rhino 8.27 (SR27) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- Annotation: Volume and Curve Length not created on current CPlane (RH-90620)
- Display: Grasshopper Annotation Dot Disappears in Viewport (RH-89180)
- File IO:
- File IO: DWG:
- Grasshopper: Custom Curve Preview is not calculating the bounding box correctly upon first opening a file (RH-90990)
- Grasshopper: Components:
- LayerStateManager: Layers from linked blocks not restoring properties (RH-90909)
- Offset:
- Print: Scripting print doesn’t work (RH-90760)
- ScriptEditor: Project Version can be earlier than previous (RH-90532)
- SDK: RhinoCommon:
- Section Style: Error saving section style with hatch pattern (RH-90683)
- Select: Subobject Left Highlighted After Undo (RH-90624)
- Trim: Objects with huge bounding box in z-direction are not trimmed properly in layout space (RH-90518)
界面相关
- Dark Mode: PackageManager install message not theme aware (RH-90433)
增强内容
- File IO: Layers in STEP should have only one PRESENTATION_LAYER_ASSIGNMENT (RH-90848)
- File IO: AI file import misses Hatch only objects (RH-85307)
- Print: Rhino.Options.Advanced.PDF.OptionalContentGroups does not work with Rhino 8 (RH-90679)
仅
相关内容
- Core Architecture: Improved loading speed for image textures (RH-90913)
- Dark Mode: Panels don’t update (RH-85095)
- Display Metal:
- Eto: GridView does not update when Dark Mode is toggled (RH-84087)
- Grasshopper: OBJ files cannot be written from OSX (RH-90500)
- Layer:
- Print: Vector output to PDF causes a crash (RH-90568)
- Quicklook: Thumbnail previews not working on macOS Tahoe (RH-90113)
宕机修复
- Eto: Drag and drop material onto object causes a crash (RH-90940)
