Rhino 8.29 发布更新
:rhinoceros: Rhino 8.29 (SR29)
Rhino 8.29 (SR29) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
  1. 请浏览这里 :point_left:,输入你的Rhino账号绑定的邮箱地址,下载更新安装包;
  2. 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
    ❖ 百度盘下载链接 :backhand_index_pointing_left:
  3. 下载 Mac 版离线完整安装包
    :green_apple: 百度盘下载链接 :backhand_index_pointing_left:
:multiply: 错误修复
  • Arc: Tangent tracking line disappears with big curves (RH-91881)
  • Autocomplete: Fails without Fuzzy Autocomplete (RH-91508)
  • ClippingPlane:
    • Exclude Selected Layer of a Block (RH-81593)
    • Selectively clipping block instances does not work as expected (RH-81994)
  • Display: Clipping display in Detail views isn’t constant (RH-85033)
  • File IO: OBJ Import Failing to Load Textures after Export from Rhino 8 (RH-91476)
  • Grasshopper: Components: File could not be read but file exists - Import Content (RH-91832)
  • Help: Draft Angle display in status bar is not documented (RH-92707)
  • PointCloud: Remove option does not maintain intensity values (RH-92002)
  • Print:
    • “Use Layout Page Size” is enabled by default for Rhino PDF (RH-92040)
    • Text Not Printed in Vector (RH-89362)
    • Hatched circles in Vector mode face camera (RH-91259)
    • Vector Print Does Not Respect Carriage Returns In Text Fields (RH-89232)
  • Repeat: Pasted alias does not repeat (RH-91531)
  • SDK: RhinoCommon: InstanceDefinitions.GetList should ignore purged items (RH-91598)
  • StatusBar: Units Don’t Refresh (RH-91834)
  • SubD: SubD ellipsoid doesn’t line up with rotated CPlane axes (RH-92023)
:locked_with_key: 宕机修复
  • Properties: Rhino crashes when adjusting linetype for a large selection (RH-91841)
:rocket: 增强内容
  • Layer: “Match Properties” supports reference layers from linked blocks (RH-91679)
  • Panels: Changing attributes with objects selected is slow (RH-91532)
:cross_mark_button: 重现错误修复
  • File IO: Importing PDF file with hatches from Illustator fails (RH-92069)
  • Print: Text with Diacritics is Changed (RH-92565)
  • Text: No Wrapping Regression (RH-92028)
:white_check_mark: 适应性修复
  • SmartTrack: Now turned off by default for refresh installation (RH-92243)
  • ToNURBS: Increased face-count warning threshold from 20,000 to 100,000 (RH-91708)
:green_apple: 仅 Mac 版相关内容
  • Annotation: Avenir Black italic face broken (RH-92290)
  • Installer: DMG background is missing (RH-91112)
  • LoadPlugin: .NET Plug-In Loader not respecting OnLoad result (RH-87887)
  • SelectionFilter: Forces popup on mac when one exists (RH-91693)
  • Model loading and view zooming slowly in SR27 (RH-91808)
❖ 仅 Windows 版相关内容
  • Undo: Inconsistency undoing a macro (RH-91577)
  • Rhino Inside: Crashes when disposing headless documents (RH-89095)
