Rhino 8.3 (SR3)
Rhino 8.3 (SR3 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
请浏览这里
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 百度网盘 请输入提取码 提取码: pye1
链接: 百度网盘 请输入提取码 提取码: tc3m
- Annotation: Dot: Dot: Display text editing box does not expand with height of dialog (RH-77041 )
- Annotation: Linetype:
- Annotation: Text: Text Panel does not show any option (RH-79011 )
- BlendCrv: Dialog not updating properly (RH-78243)
- CPlane: AutoAlign: Sticky mode toggle doesn’t script correctly (RH-78528)
- Containers:
- Removed OSnap panel reappears after restart (RH-77605)
- PopUp a container blanks the buttons on the floated version (RH-78476)
- When sidebar is pinned, clicking on Properties or Layer icon in the main toolbar should unfold the sidebar (RH-78750)
- Flyout toolbar closes container popup (RH-78152 )
- Container: Right sidebar hides when hovering to another tab (RH-78749)
- Delete: Slow on mesh subobjects (RH-78652)
- Display:
- Docking: Osnaps and Filter glitch (RH-78363)
- DocumentProperties: Hooked up custom units in the scriptable command (RH-8990)
- Enter: Mouse right click repeat is slower than Space or Enter (RH-78895)
- File IO:
- Grasshopper: Cannot copy with wire drag using alt key on Mac (RH-78693)
- Helix: Helix - accept default radius on Enter (RH-79441)
- History: Loft with Pt input - Tangency is lost after update (RH-78922)
- Insert: Does not remember the “Insert as” setting (RH-44370)
- Intersect: Point intersection not being detected (RH-78423)
- Layer: Double-click leaves layer unselected (RH-78854)
- Make2D: Missing clipping-plane intersection curves (RH-78825)
- NamedView: Panel not populating when opening recent file from splash screen (RH-78696)
- OSnap:
- Options: WindowColor 3 does nothing (RH-62608)
- Print:
- No longer export to a vector PDF in Pen mode or other shaded modes (RH-79092)
- Closed polyline missing a segment (RH-79094)
- Vector PDF output from technical creates white hatch (RH-79221)
- Ensure selected printer exists before trying to recall settings (RH-78904)
- Very very slow on Mac (RH-78885)
- Rhino PDF won’t print multipages with vector output (RH-78674)
- Raster printing line width issues (RH-78687)
- RDK: Physical Sky texture controls don’t work properly (RH-78305)
- RefitTrim: Fails on surface with singularity at opposite end (RH-73421)
- Rendering: Content Panels: Pixelated icons in Lights panel (RH-78679 )
- Rendering: Cycles:
- Rendering: Materials:
- Rhino Installer Engine: Installed plugin appears twice in the Menu (RH-78113)
- SDK: Add IsWcsProjected and IsWcsBoxProjected to ON_Texture and Rhino.DocObjects.Texture (RH-78920)
- SDK: RhinoCommon:
- DrawSubDWires method is not working (RH-78897)
- Brep.JoinBreps modifies edges (RH-78899)
- Exposed EarthAnchorPoint to Rhino.FileIO.File3dmSettings (RH-34447)
- Added bounding box overrides to Rhino custom objects (RH-32678)
- ShrinkWrap offset and smoothing have no effect on Point Clouds (RH-78656)
- MeshLine leaks memory (RH-78469)
- ScriptEditor:
- ScriptEditor close buttons should have light and dark mode icons (RH-79361)
- Single script component is missing when language is not initially available when gh plugin is loaded (RH-79552)
- Point3d is missing .Clone() and .Duplicate() in python 3 (RH-77315)
- References assemblies in #r do not work in python (RH-79116)
- Non-single file assemblies fail to load in Pythonnet (RH-78289)
- Use Object does not load when base component updates legacy parameters to new ones (RH-79338)
- RhinoScriptSyntax mesh.py has a CPython error in AddMesh (RH-79163)
- Node in code Python returns troubling (RH-78865 )
- Roslyn does not compile when Memory Load is enabled in GrasshopperDeveloperOptions (RH-78555)
- No module named ‘scriptcontext’ (RH-78435)
- Pretty name should match Variable name when is not set specifically (RH-78616)
- Editor sometimes resets caret position to the top in Grasshopper script component (RH-78618)
- Int parameter is converted to “Object Print Width” parameter when using new script editor compiler (RH-78617)
- Applying modified script to component is awkward now with the “Do you want to save” prompt addition (RH-78543)
- Make sure type hinting works for linked scripts (RH-78090)
- Section Tools: Clipping drawing location jumps (RH-77320 )
- Selection:
- SetDisplayMode: Display Mode > Object > SubD options not sticking (RH-78918)
- SetDocumentUserText: The Document User Text panel doesn’t update when importing a 3DM file with Document User Text (RH-78846)
- ShadeOptions:
- SrfSeam: Fails in V direction of a surface (RH-56626)
- Sun: Daylight saving checkbox is broken (RH-78824)
- Toolbar:
- Rhino 8 showing duplicate menus from plug-ins (RH-78914)
- Difficult to close “Default Toolbars” when importing from Rhino 7 RUI (RH-78858)
- Duplicating a button needs the Macros command to properly change the tooltip (RH-79138)
- missing icons in select dimensions toolbar (RH-78748)
- Missing icon in visibility toolbar (RH-78756 )
- WindowLayout: Duplicate sidebars on Mac (RH-70348)
- Issue of button and text setting (RH-78383)
- PopUp is slower on Mac (RH-76248)
- UI Appearance:
- WindowLayout: Include tab size settings in exported RHW file (RH-77995)
界面相关
- File IO: Fixed capital letter file extensions when exporting AI files (RH-78651)
- ScriptEditor: Fix Input as Path Icon on Grasshopper component (RH-78210)
- Toolbar: “Size to Content” does not re-size floating container properly (RH-70719)
宕机修复
- Make2D: Cannot cancel properly (RH-78990)
- ScriptEditor: Passing function to Rhino.RhinoApp.InvokeOnUiThread() crashes Rhino (RH-79021)
改善内容
- BlockManager: Added “Group similar block instances” setting (RH-77975 )
- Code Editor Control: Provide snippet completions like found in Rhino 7 Gh C# scripting components (RH-78789)
- Docking: Added margin around sidebar to avoid auto-hiding accidently (RH-77224)
- File IO:
- Grasshopper: Added Transpose Surface and Reverse Surface components (RH-77254)
- Gumball: Maintain relocation for sub-object editing until selection is cleared (RH-75509)
- Offset: Closing offset arcs into circles if they form a region (RH-78494)
- Osnap:Point: Now snaps to points on the near side of a point cloud (RH-10862)
- Rendering: Cycles Viewport: Added device state indicator and “Recompile kernels” and “Show compile log” buttons (RH-78682)
- ScriptEditor: Allow RhinoCode homedirectory to be changed from Rhino (RH-78915)
- Shrinkwrap: ShrinkWrap: Added “Compute vertex colors” checkbox (RH-75395)
新增特征
- Enter: Added DisableRightClickAsEnter advanced setting (RH-20644)
- ScriptEditor: Expose virtual envs for cpython (RH-66285)
- SelChildern: SelChildren: Added IgnoreAnnotations=Yes/No option (RH-63113)
- Toolbar: Added “Cascade as menu” setting back (RH-67717 )
- Annotation: Linetype: Model space pattern scale gone missing (RH-79307)
- Grasshopper: Extruding surface issue (RH-79261 )
- Print: Control points on “single selected” Objects Print (RH-79362)
- Properties: Glitch of renaming materials (RH-78477)
- Rendering: Materials: Sorting alphabetically does not update the list (RH-78839 )
- Rendering: Texture Mapping: Texture baking UVW transform wrong on WCS projected textures (RH-78975)
- Rendering: Textures: Image paths need to be editable (RH-78427)
- ScriptEditor:
- Grasshopper component does not show previews on output parameter (RH-79120)
- “Out” parameter on new Script component is not removable from ZUI interface (RH-78322)
- Implement custom iter and len extensions for Pythonnet (RH-78987)
- GH Python3 output polyline is different from IronPython (RH-79323)
- Grasshopper python input string is incorrectly a
list(RH-79030) - CPython does not apply implicit casting especially when dealing with operator overloads (RH-79099)
- CPython Point3d non-iterable problem (RH-79162)
- VB Script Component in GH should not be Obsolete (RH-78855)
- Python 3 can not slice dotnet lists (RH-78908)
- Allow indexing and slicing on grasshopper inputs lists in python 3 (RH-76311)
- Improve script component exec performance (RH-78353)
- Pass Grasshopper list inputs as List<> into the scripts. Figure out a way to generate python 3 lists for inputs (RH-78321)
- Toolbar: Float To Top does not work (RH-77681)
SDK (开发工具)增强
- File IO: Support exporting glTF programmatically with options (RH-78795 )
- SDK: Exposed RhGetTanPerpPoint to the C++ SDK (RH-78612)
- SDK: RhinoCommon:
UI 调整
- ClippingPlane: Made clipping planes only snapped by Point OSnap at three locations where control points show (RH-78226)
- Layer: Disabled Delete key in Layers panel for deleting layers (RH-78615)
- Options: Toolbar Options Page: Eliminate weird macOS UI (RH-78781)
- Properties: Changed type name of Picture from “surface” to “picture surface” (RH-78414)
- Section Tools: ClippingDrawings command now sets print width to ByLayer (RH-78060)
- Toolbar: Replace Gear with menus in Edit Image dialog (RH-79395)
实用性问题修复
- Grasshopper: Undo action regression from v7 to v8 (RH-78853)
- Grasshopper: Bake: Output objects don’t land on selected layer (RH-78959)
- Properties: Viewport info hard to read in dark mode (RH-78521)
- ScriptEditor:
- Modify python error diag to say use .NONE instead of .None (RH-79152)
- Grasshopper window drags really slowly when there are many script components placed on the canvas (RH-79189)
- Add
import mathto python template scripts in editor and Grashopper (RH-79154) - Put language init window on a timer so it opens after a second or so (RH-77294)
- Record component script saves in Grasshopper undo history (RH-78544)
- Python lint to mention to use .NONE instead of .None (RH-77801)
- Input parameter Name filed is a little visually distracting from the Variable Name field (RH-78552)
- Improve discoveribility of creating languages in new script component (RH-76674)
- Modify C# script and add default assignments to out parameters (RH-78547)
- SelLayer: Spacebar should act as Enter key in dialog (RH-78761)
仅 Mac版调整内容
- Containers:
- Display: Custom color not working for surface naked edges (RH-78568)
- Panels: Floating a container outside of virtual desktop causes container to disappear on Mac (RH-69542)
- SmartTrack: Status bar does not update on Mac (RH-78660 )
- UI Appearance: Mac: Command feedback is too slow and distracting (RH-77197 )
- WindowLayout: Ignore the left sidebar (RH-76415)
宕机修复
- Export: Crash: ExportAll to 3DS, OBJ in 8.3 (RH-79550)
新增特征
- Rendering: Post Effect: Intel denoiser is now integrated into Rhino 8.3 and works on Apple Silicon (RH-71149)
- Print: Vector output prints layouts upside down (RH-76966)
UI调整
- Options: Hide ShowFullPathInTitleBar in advanced settings on Mac (RH-54289)
实用性问题修复
- Analysis: EdgeContinuity: Only last digit of input number shows (RH-78685)
❖ 仅 Windows 版调整内容
- Grasshopper: Rhino.inside.Revit starts to flash and spin the cursor in latest versions (8.2-8.3) (RH-78879)
- Panels: Some panels do not fade out (RH-75220)
- Print: 3rd party pdf writers & Physical Printers not saving correct page dimensions (RH-77985)
- ScriptEditor: Crash with SaveAs same file name (RH-79103)
- Settings: Raytraced mode settings won’t restore to defaults or un-highlight (RH-38066 )
- UI Appearance: Rhino 8 looses focus when dragging out a cascaded toolbar (RH-78099)
增强内容
- Display: Edges in technical display modes display faster (RH-76241 )
- Section Tools:
- Layer: Layer names cannot copy and paste from right-click menu (RH-78025)
