Rhino 8.30 (SR30)
Rhino 8.30(SR30) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- BlendSrf:
- Grasshopper: Bugs on empty branches (RH-91952)
- LayerStateManager: Layer states are unpredictable (RH-92648)
- Layout: Move to paperspace/modelspace (RH-2572)
- PointCloud: Subobject delete does not maintain intensity values (RH-92381)
- Print: Linetype Width is Scaled by Detail’s Scale Factor (RH-93524)
- PushPull: Makes a closed polysurface open (RH-92583)
- Rendering: Materials: Unused Materials should have a chance to get deleted (RH-92184)
- SDK: RhinoCommon:
- SelDup: SelDup and SelDupAll get confused with circles (RH-92547)
- Text: View aligned text not visible in all viewports (RH-92227)
- ViewCaptureToFile: Captured image is darker if transparent background is enabled (RH-
增加特征
- Grasshopper: Added ToNURBS options for SubD conversion (RH-61955)
性能改善
- RDK: Lag in selecting Rhino Object after GH file with clusters has been opened (RH-92155)
- BlendSrf: Fails in v8 and v9, but works in v7 (RH-89796)
- SDK: RhinoCommon: SubDVertex.Tag setter broken in WIP (RH-94186)
仅 Mac 版相关
错误更新
- Display Metal: Pointcloud points don’t highlight with sub-object selection (RH-92548)
- Rendering: Cycles: AMD GPUs not working with latest drivers (RH-92187)
- Rendering: Materials: Rendering Material: Texture color washed out on Mac (RH-91151)
