Rhino 8.31 (SR31)
Rhino 8.31(SR31) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
错误更新
- Annotation: Leader: “\n” does not work in macro (RH-67179)
- BoundingBox: Wrong Result (RH-94035)
- File IO: Changed topics opened from STL meshing dialogs (RH-94008)
- MatchSrf: OnSurface moves the edge too far and create a dense surface (RH-94592)
- MergeAllCoplanarFaces: Fails on Extrusion Objects (RH-93907)
- NamedView: Crashes when saving a second named view (RH-94533)
- Panels: UI isn’t purged from panel definitions when tab is disposed (RH-92375)
- SDK: RhinoCommon: RhinoObject.SetObjectFrame throws exception (RH-94175)
- Toolbar:
宕机修复
- RDK: MeshUnwrapper object freeze bug (RH-69383)
增强内容
- SVG Editor: Added Help topic (RH-93924)
- BlendSrf: Failure regression from 8.29 (RH-95133)
仅 Mac 版相关
- Toolbar: Flashing tooltips (RH-78371)
