Rhino 8.32 (SR32)
Rhino 8.33(SR32) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- BlockEdit: Block Edit: hidden/locked elements always removed from block even when “No” is selected in the warning window (RH-49763)
- ClippingPlane: Incorrect BoundingBox with Custom Depth (RH-94974)
- CPlane: Orienting CPlane to rotated clipping plane gives inconsistent results (RH-94811)
- File IO: DWG: Cherry-pick changes for RH-88129 into 8.x (RH-94802)
- Isolate: Does not affect Worksession reference objects (RH-95392)
- OpenNURBS: ON_wString works poorly on Linux (RH-94588)
- PackageManager: Clean up old package versions during startup (RH-95390)
- PointGrid: Always parallel to CPlane (RH-94891)
- RecordAnimation: No shadows in output images (RH-94813)
- ScriptEditor:
- SDK: RhinoCommon: Linetype.CreateFromPatternString should work with negative segment values (RH-95417)
- Toolbar:
增强内容
- ScriptEditor: Static properties return ‘property’ type instead of actual value (RH-94780)
- BlendCrv: Error about Edit option of BlendCrv (RH-47026)
- LayerStateManager: Unlinks Model On from On (RH-94805)
- SDK: Intersection.BrepPlane Bug (RH-91978)
开发工具增强
- SDK: RhinoCommon:
仅 Rhino Mac
- Panels: Layer panel doesn’t register left click when floated on Mac (RH-95130)
- Toolbar: Toolbar list appears in wrong location (RH-81270)
- UI Appearance: Toolbar popup pops up off screen partially on mac (RH-75869)
