Rhino 8.33 SR33 发布更新
:rhinoceros: Rhino 8.33 (SR33)
Rhino 8.33(SR33) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
  1. 请浏览这里 :point_left:,输入你的Rhino账号绑定的邮箱地址,下载更新安装包;
  2. 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
    ❖ 百度盘下载链接 :backhand_index_pointing_left:
  3. 下载 Mac 版离线完整安装包
    :green_apple: 百度盘下载链接 :backhand_index_pointing_left:
:white_check_mark: 错误修复
  • ClippingPlane: Curve does not display control points (RH-95566)
  • Grasshopper:
    • Far-from-origin points don’t display accurately (RH-87912)
    • Annotation bounding boxes produce incorrect results in Grasshopper vs. Rhino — model space scale not applied consistently (RH-96024)
    • Typo - Set Difference - Substraction > Subtraction (RH-95937)
  • LayerStateManager: Causes objects to remain hidden when their layers are turned on (RH-96097)
  • Localization: SVG Editor not fully localized (RH-94860)
  • Menu: Updated User’s Guide link (RH-96151)
  • PrintPreview: Grips occluded with thick wires (RH-95084)
  • Properties: Unchecking “Custom Mesh” resets custom settings (RH-95872)
  • ScriptEditor:
    • Open python shell runs conda init (RH-95910)
    • Published plugin asks for already installed plugin on load (RH-95862)
  • Splash and Greet: Splash and About: Link to page gives error (RH-96327)
  • SubDTruncatedCone: SubD and MeshTruncatedCone do not align to custom CPlane (RH-95602)
  • TextField: GUID is Automatically Changed (RH-95882)
:rocket: 增强内容
  • PackageManager: Enhanced Search (RH-95404)
:cross_mark: 重现错误修复
  • Display: Rendered view in layout is not gamma corrected (RH-95022)
:cross_mark_button: 适应性问题修复
  • Reflect: Direction Arrow Color Not Adjustable (RH-95180)
  • ScalePositions: Use feedback color for DynamicDisplay (RH-95873)
:green_apple: 仅 Rhino Mac 相关
  • NamedView: Named view widgets (and decal widgets) don’t disappear on Mac when Escape key is pressed (RH-94096)
  • Preferences: File search path locations do not stick (RH-93697)
  • ViewCaptureToClipboard: ViewCaptureToCliboard: Yellow shadow silhouette on transparent background on MAC (RH-95560)
    Background Turns Black in Active Detail (RH-95737)
❖ 仅 Rhino Win 相关
  • Isolate: isolate hides locked layer objects (RH-95243)
