Rhino 8.6 (SR6)
Rhino 8.6 (SR6) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 点击这里进入百度网盘下载
链接: 点击这里进入百度网盘下载
- CPython Env Reset Doesn’t Reimport Modules (RH-79880)
- Annotation: Hatch:
- BlendCrv: History update problem (RH-59212)
- BlockManager: Issue about listing definitions without instances (RH-69713)
- ChangeLayer: Select Not Using Sublayer (RH-80799)
- Code Editor Control: ScriptEditor: Break points not displayed (RH-80902)
- Detail: Print display does not remember DetailBorder setting (RH-78522)
- Displacement: Moving object recalculates displacement mesh (RH-72387)
- Display:
- Shadows incorrect on selected block instances (RH-80922)
- Set object display mode issue (RH-75329)
- Curves move around when zooming in closely (RH-81185)
- GPU tessellation setting makes highlighted edges not look as good as they did in v7 (RH-73635)
- Raytrace kills locked object display (RH-80703)
- “Show shadows only” fails with self-illuminating ground plane material (RH-80599)
- Clipped block instances not displayed correctly in technical modes (RH-80614)
- Flickers intermittently for a split second (RH-75091)
- Image backgrounds in Detail views don’t print/tile correctly (RH-80670)
- Ground plane in detail views gets clipped (RH-80532)
- Two Point Perspective shows horizon line (RH-80177)
- Document UserText:
- DraftAngleAnalysis: Draft angle curves don’t get generated on second file (RH-80483)
- ExtractPipedCurve: Creates invalid mesh (RH-74078)
- ExtrudeCrvTapered:
- File IO:
- FilletEdge: Filleting on multiple objects with Preview=Yes does not preview all results (RH-80809)
- Grasshopper:
- Grasshopper 2: GH2 documentation fails to show. (RH-80701)
- Grasshopper: Components:
- Group: RemoveFromGroup command - Toggling Copy option clears current selection (RH-80803)
- Gumball:
- Oriented to Plane in Block regression (RH-80593)
- Clicking on handle repeats last command (RH-79440)
- Should remember SubD subobject orientations (RH-79013)
- Extrude relocates gumball of extruded object (RH-80522)
- Relocate does not show snap highlight (RH-80451)
- Relocate does not snap to occluded positions (RH-80439)
- Help: ExtractSrf options (RH-80528)
- Isolate: Undo breaks Unisolate (RH-57579)
- Keyboard Shortcuts: Default shortcuts cannot be overridden (RH-80307)
- Layer:
- Layout: Editing name in Layouts panel ignores case change (RH-80833)
- Lights: Skylight intensity adjustment fails (RH-80759)
- LineTypeDisplay: LinetypeDisplay: DisplayLinetypes option does not work (RH-81101)
- MacroLibrary: Macro dialog does not show icons in dark mode (RH-81065)
- Make2D: Draws clipped block instances as unclipped (RH-80723)
- Mesh:
- Ortho: Tracking along Z axis is forbidden with shallow view angles (RH-80760)
- PointGrid: Failure caused by grid size limitation (RH-80507)
- Polyline: Visual glitch of flashing polyline control points (RH-81310)
- Print:
- PrintPreview: Add “Model Unit” Scaling to linetype (RH-79551)
- Properties:
- RDK: Problem with CRM sample code (RH-79937)
- Rendering:
- Environment rotation not updating in Raytraced display mode (RH-80731)
- Saving depth channel should not alter information put into it (RH-80330)
- Adjusting ground plane texture makes it disappear in Raytraced mode (RH-80625)
- Texture mapping changes don’t update in Raytraced mode (RH-80626)
- Editing material triggers unnecessary re-calculation of edge softening (RH-80340)
- Material Ids and Object Ids not visualized properly (RH-80263)
- Depth channel lacking resolution (RH-61748)
- Rendering: Content Panels: Sliders are hard to use (RH-80433)
- Rendering: Post Effect: Bloom doesn’t update while adjusting (RH-75586)
- Rendering: Texture Mapping:
- Rendering: Textures: OpenGL previews broken on Mac with dots texture (RH-80573)
- SDK: ModelComponent.TextureMapping unimplemented (RH-80456)
- SDK: RhinoCommon: MessageBox not wrapping (RH-80166)
- ScriptEditor:
- Script param converter regression in 8.6 (RH-81269)
- Add zoom support on terminal (RH-81243)
- Add System.Linq as a default import to csharp templates (RH-81237)
- ghpythonlib CullDuplicates can not convert python 3 inputs (RH-81296)
- Python 3 stream wrapper does not have .fileno() method (RH-81299)
- Rectangle to Polyline type hints turns to point?! (RH-81302)
- GH editor closes on save and it is annoying (RH-81303)
- Python 3 converts polyline inputs to list of points (RH-81314)
- Add undo support to editor to undo converting to script instance and other changes to script by editor host (RH-77882)
- Remove script option not working (RH-81353)
- Autocomplete over-population (RH-81248)
- Sticky “Restore Packages” progress bar when running published commands (RH-81100)
- Script component does not run when input has cast error (RH-81109)
- List and Tree conversion error on null input has bad message (RH-81162)
- Improve error capture on display conduits (RH-80928)
- Search broken during debugging (RH-76162)
- Old tags don’t show up on published components (RH-78088)
- Gumball does not show when script ends (RH-79039)
- Does not show Gumball on selected face (RH-79525)
- Project scripts in IronPython should show the correct icon (RH-78106)
- Python 3 does not autocomplete DriveInfo (RH-80427)
- RUI files from ScriptEditor will have tags if dark icon is not specified (RH-80820)
- ScriptInstance does not throw ExecuteException (RH-80755)
- Fix installing
dlibin CPython (RH-77989) - Sometimes empties script if also open in VSCode (RH-80416)
- Modify published plugins to load RhinoCodePlugin (RH-80394)
- Selection: Dot picking fails (RH-80574)
- SetDisplayMode:
- SmartTrack: SmartOrtho incorrectly doubles diameter of circle (RH-81183)
- SubD: Sharp edges:
- Surface-surface intersection: NonManifoldMerge and trim type issue (RH-77064)
- Templates: Notes missing from Small mm Small inches feet template files (RH-80208)
- TextField:
- Toolbar:
- Container properties not saved in rui (RH-81160)
- Button appearance is not saved (RH-81362)
- Snap to button edge when adjusting width of vertically docked toolbar containers (RH-81315)
- Importing SVG hangs button editor (RH-78367)
- Button images not saving (RH-81059)
- Button images lost on save of RUI (RH-81060)
- Editing a menu is not possible (RH-81070)
- Saving to single RUI causes several problems (RH-81035)
- Saving a RUI file doesn’t store the menu associated with it (RH-79994)
- Cannot delete toolbar group (RH-79987)
- Tooltip shows up after cursor leaving the button (RH-80270)
- UDT: SubD captive incorrectly released from cage when whole control object is moved (RH-80426)
- UI Appearance: Toolbar height needs to snap to button heights. (RH-71925)
- UVEditor: Edited object show gray and black (RH-50599)
- Units: Absolute tolerance is not scriptable (RH-81016)
- ViewPropertiesPage: Viewport size can be set larger than Rhino window (RH-59260)
界面调整
- ScriptEditor:
- Annotation: Linetype: Changed text buttons in Linetypes document properties to icon buttons (RH-80449)
- Containers: Hide “Show Panels” menu item on containers with only toolbars (RH-79980)
- Section Tools: ShowSolidClipping is renamed to ShowSolid in NestedClippingDrawing command (RH-80158)
宕机修复
- OpenNURBS: Repeatable crash in Mesh.CreateFromIterativeCleanup (RH-80032)
- Rendering: Crash opening EXR without alpha channel (RH-80730)
- ScriptEditor: C# script with NuGet reference crashes on non-ui thread (RH-79758)
- Toolbar: Deleting menu and saving the RUI hangs Rhino (RH-81069)
增强内容
- Annotation: Hatch: Allows selecting with Shift and Ctrl key on import list (RH-80699)
- BlockManager:
- ClippingPlane: Increased precision of custom depth to 3 decimals (RH-80996)
- Documentation: /runscript command line documentation improvement (RH-80848)
- File IO:
- Grasshopper:
- Gumball: Alignment mode now sticks across Rhino sessions (RH-80583)
- History: Editing control points of an angular dimension updates its position in history record (RH-80816)
- Ortho: Added ShowOrthoHashMarks advanced setting for turning off angle hash marks (RH-80798)
- Print:
- RebuildEdges: Now removes micro naked edges (RH-80666)
- Rendering:
- SDK: RhinoCommon: Added SaveToLibraryFile method for textures (RH-80872)
- ScriptEditor:
- Add Option to avoid closing editor window when saving in GH (RH-80898)
- Support drag-drop of multiple .py files (RH-52159)
- Support importing cs files in cs scripts using #load directive (RH-80364)
- Fold using and notes sections in Grasshopper init scripts (RH-78546)
- -ScriptEditor _Run now supports using system environment variables in file path (RH-80852)
- -ScriptEditor _Run now looks in Rhino’s search path (RH-80851)
- Added a “Add/Install Package” to the dashboard that installs a package on active script (RH-79155)
- Section Tools: Added PrintWidth=ByLayer/ByInputObject option to ClippingDrawings and EditClippingDrawings commands (RH-80218)
- Selection: SelKey, SelValue, and SelKeyValue commands support wildcards “?” and “~” (RH-80384)
- Toolbar: Snap to button edge when adjusting height of horizontally docked toolbar containers (RH-74842)
新增特征
- Grasshopper: Added new datatype for Lights (RH-79341)
性能改善
- ScriptEditor: Minimize RhinoCodePlugin assembly loading footprint on Rhino start (RH-80380)
修复重现错误
- ExtrudeCrvTapered: Missing surfaces (RH-80865)
- Gumball: Location not saved for individual objects in v8 (RH-80353)
- Join: Duplicates disjoint SubDs (RH-81242)
- LineTypeDisplay: PatternBySegment ignored in V8 (RH-80715)
- Print: No dialog appears (RH-80907)
- ScriptEditor:
- Volume: Unable to calculate from extrusions in blocks (RH-81079)
开发工具增强
- SDK: RhinoCommon: Allows updating status bar progress label (RH-80733)
适用性问题修复
- ScriptEditor:
- Cleanup NuGet package reference formats (RH-81308)
- Python 3 to set locale before running script (RH-81130)
- Confirm clear recents (RH-80927)
- Does not show any indication of errors when Problem tab icon is turned off in Rhino options (RH-79151)
- Display language init progress on GH component (RH-80510)
- Script Editor to notify when installing packages but make it block the UI (RH-79324)
- Move Toggle debug trays from Run menu to Window menu (RH-78549)
- Add scripts path to PATH when launching Python3 shell (RH-80719)
- Console panel buttons on the right are less discoverable (RH-80717)
- Improved package install visual feedback (RH-80718)
- New file from template does not add second file (RH-78599)
- Allows modifying compact options from the Window menu (RH-78551)
- File dialog opens behind editor (RH-80210)
- Stop debug on error (RH-79790)
- Allows scrolling through document tabs with mouse wheel (RH-79431)
仅 Mac 相关内容
- Display Metal:
- Keyboard Shortcuts: Keyboard: Shortcuts: Overriding macOS shortcuts does not work (RH-78732)
- Modeling Aids: OSnap highlight setting on Mac doesn’t change anything (RH-80452)
- Options: StatusBar command locks up Rhino for Mac (RH-80756)
- Panels: Settings out of sync (RH-80601)
- Print:
- Rendering: Materials:
- ScriptEditor: Cannot run script without first opening the editor (RH-80560)
- Toolbar:
- ViewCaptureToFile:
- WindowLayout:
增强内容
- Display: Added NURBS surface remeshing toggle and timing settings for Nudge keys to Advanced settings (RH-80496)
修复重现错误
- CommandHistory: Cmd-C not copying text to clipboard as in v7 (RH-81154)
- Containers: Don’t stay in place when opening new document (RH-80204)
❖ 仅 Windows 相关内容
- Annotation: Linetype: “Add Defaults” not working properly on Windows (RH-80740 )
- BlockManager: Should use block names on export (RH-57137)
- Display:
- Lights: Text of numeric values uses incorrect color after editing in Dark mode (RH-80925)
- Print: Printer properties not working in v8 (RH-79796)
- Rendering: RGBA channel button missing in Render window (RH-80935)
- Rendering: Texture Mapping: Procedural texture on sub-object has seams and when editing mapping on single objects (RH-69154)
- SDK: RhinoCommon:
- Section Tools: ExportClippingDrawings: Fail on elevations (RH-80885)
- Toolbar:
- UI Appearance: Light mode icons are used in fly-outs (RH-77241)
- UVEditor: Importing geometry with UVEditor open causes error message (RH-80099)
修复重现错误
- Display: Receives Shadows setting is broken in V8 (RH-80390)
- Print: Custom Page Sizes not available for Printer (RH-80709)
达成计划任务
- Help: Added traditional Chinese offline help for download (RH-80983)
