Rhino 8.1 (SR1) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
请浏览这里
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 百度网盘 请输入提取码 myni
链接: 百度网盘 请输入提取码 v5ks
- Retain print settings for file after rhino restart (RH-77614)
- RhRdkAssignMaterialToLayers doesn’t work properly (RH-78413)
- Delete: Fails to delete mesh edges (RH-56326)
- Display Metal: Rendered viewport shows colorful artifacts (RH-77271 )
- Gumball: Cut action always creates bad results from meshes (RH-77841 )
- Layer: Layers panel not ending undo record (RH-78325)
- LayerStateManager: Model On state is not restored (RH-77719)
- Localization: FitCurveToSurface shows comma in result (RH-78237)
- Print:
- Rendering: Cycles:
- SDK: RhinoCommon:
- ScriptEditor:
- Subobject Selection: SubD face selection is harder (RH-78173)
- TextObject: Text editing field not visible (RH-78227)
- Toolbar: Cannot close default toolbar collection in Rhino skip apps (RH-76105 )
- Display: Sub-object editing a SubD doesn’t shade the preview anymore (RH-78065 )
- BlockManager: Incorrect selection state on block instances (RH-77501)
宕机修复
- Rendering: Textures: Crash bug when reusing blend texture (RH-78144)
增强内容
- File IO: Added AcadExportSelectUnexportableObjects advanced setting to highlight skipped objects for saving DWG/DXF files (RH-77693)
- Grasshopper: Create Get Plane Context Component (RH-76599 )
- Print: Rhino PDF remembers DPI setting (RH-57008)
- PushPull: Added Loose option (RH-76269 )
- Grasshopper: Components: Allows setting Model Linetype and Hatch Scale in Grasshopper (RH-77367)
仅 Rhino Mac 修复
- Annotation: Hatch: Unable to use custom hatch patterns (RH-77747)
- Core Architecture: Idle Handler Affects Trackpad Performance (RH-78073)
- Rendering: Materials: Sliders misbehave (RH-78222)
- Selection: Objects don’t select from popup (RH-78370 )
- Settings: Plugins: Allow plugin registration in com.mcneel.rhinoceros.x.plist (RH-77912)
- Options: Settings > Mouse > context menu control missing (RH-78170 )
- Display Metal: Metal: Intel Macbooks cause visual glitch in shaded mode due to wire drawing (RH-77938)
