private void RunScript(object BREP, ref object DS)
// AddMaterial component to create a material
var addMaterial = Components.FindComponent("RhinoInside_AddMaterial");
// and AddGeometryDirectShape to create a DirectShape element in Revit
var addGeomDirectshape = Components.FindComponent("RhinoInside_AddGeometryDirectShape");
if (addMaterial == null || addGeomDirectshape == null)
throw new Exception("One or more of the necessary components are not available as node-in-code");
if(BREP != null) {
// create a color object. modify the logic as you wish
var color = System.Drawing.Color.FromName("DeepSkyBlue");
// now create the material using the node-in-code
// note that just like the Grasshopper component, the node-in-code also
// takes 3 inputs in the exact same order (top to bottom)
var newMaterials = addMaterial.Invoke("Sky Material", true, color);
// and now use the AddGeometryDirectShape node-in-code to
// create the DirectShape element in Revit
// Notes:
// - BREP is our input Brep object
// - new_materials is a list of new materials so we are grabbing the first element
// - get_category is a function that finds a Revit category from its name
var dsElements = addGeomDirectshape.Invoke
"Custom DS",
GetCategory("Walls"),
BREP,
newMaterials[0]
// assign the new DirectShape element to output
DS = dsElements[0];
public DB.Category GetCategory(string categoryName)
var doc = RIR.Revit.ActiveDBDocument;
foreach(DB.Category cat in doc.Settings.Categories)
if (cat.Name == categoryName)
return cat;
return null;
if(BREP != null) {
// Notes:
"Custom DS",
BREP,
newMaterials[0]
DS = dsElements[0];
//方法
return cat;
return null;
using System;
using System.Collections;
using System.Collections.Generic;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using DB = Autodesk.Revit.DB;
using UI = Autodesk.Revit.UI;
using RIR = RhinoInside.Revit;
using RhinoInside.Revit.Convert.Geometry;
using Rhino.NodeInCode;
/// <summary>
/// This class will be instantiated on demand by the Script component.
/// </summary>
public class Script_Instance : GH_ScriptInstance
#region Utility functions
/// <summary>Print a String to the [Out] Parameter of the Script component.</summary>
/// <param name="text">String to print.</param>
private void Print(string text) { /* Implementation hidden. */ }
/// <summary>Print a formatted String to the [Out] Parameter of the Script component.</summary>
/// <param name="format">String format.</param>
/// <param name="args">Formatting parameters.</param>
private void Print(string format, params object[] args) { /* Implementation hidden. */ }
/// <summary>Print useful information about an object instance to the [Out] Parameter of the Script component. </summary>
/// <param name="obj">Object instance to parse.</param>
private void Reflect(object obj) { /* Implementation hidden. */ }
/// <summary>Print the signatures of all the overloads of a specific method to the [Out] Parameter of the Script component. </summary>
private void Reflect(object obj, string method_name) { /* Implementation hidden. */ }
#endregion
#region Members
/// <summary>Gets the current Rhino document.</summary>
private readonly RhinoDoc RhinoDocument;
/// <summary>Gets the Grasshopper document that owns this script.</summary>
private readonly GH_Document GrasshopperDocument;
/// <summary>Gets the Grasshopper script component that owns this script.</summary>
private readonly IGH_Component Component;
/// <summary>
/// Gets the current iteration count. The first call to RunScript() is associated with Iteration==0.
/// Any subsequent call within the same solution will increment the Iteration count.
/// </summary>
private readonly int Iteration;
#endregion
/// <summary>
/// This procedure contains the user code. Input parameters are provided as regular arguments,
/// Output parameters as ref arguments. You don't have to assign output parameters,
/// they will have a default value.
/// </summary>
if(BREP != null) {
// Notes:
"Custom DS",
BREP,
newMaterials[0]
DS = dsElements[0];
// <Custom additional code>
return cat;
return null;
// </Custom additional code>
