Rhino 7.28 (SR28) 发布更新,所有 Rhino 7 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可链接:
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: https://pan.baidu.com/s/1hT3_NLj6cXKmOjkvmKk1vA?pwd=injm 提取码: injm
链接: 百度网盘 请输入提取码 提取码: y95n
- Angle: Incorrect with some edges (RH-73003 )
- File IO:
- GumballAlignment: Axes directions of Gumball (align to object), UVN, MoveUVN were incorrect for control points on SubD-friendly curves (RH-72629)
- Help: BooleanIntersection needs to be added to the list on History’s Help page. (RH-72462)
- Licensing and Validation: License manager dialog hidden behind all other open windows (RH-71806 )
- RDK: “Properties: Materials” panel did not show options (RH-72737)
- Rendering: Materials: Layers in Choose Layers dialog did not list in alphabetical order (RH-72595)
- Revolve: History shifted the axis (RH-65682)
- SDK: RhinoCommon: rs.ObjectColor() always returned A (transparency) value as 255 (RH-72572)
- Sun: Daylight saving in Eto dialog did not work properly (RH-73045)
- UDT: Flowed object and naked edges (RH-42841)
❖ 仅Win 版本的错误修复
- Notes: Text in Notes panel was all selected when Rhino window regaining focus (RH-65292)
