Rhino 8.2 (SR2)
Rhino 8.2 (SR2 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
请浏览这里
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 百度网盘 请输入提取码 gxsx
链接: 百度网盘 请输入提取码 h5aa
- Object properties panel - ensure Delete key clears Name text selection (RH-77630)
- Annotation: Linetype: Linetypes panel out of sync with document properties (RH-78483)
- Bridge: Options dialog does not display Dark mode (RH-78377)
- CPlane: AutoAlign: Ngon failure sample (RH-78462 )
- Code Editor Control: Show vertical scroll bar when minimap is turned off (RH-76133)
- CurvePiping: The source curve missing properties for the piping mesh (RH-78405)
- Dark Mode: Set dark mode by code (RH-78558)
- Display:
- Block: Text In Block Not Displayed Horizontal to View (RH-75332)
- Block transparency issue (RH-75335)
- TriangulateMesh and display pipeline use different quads (RH-72067)
- Dynamic feedback of shaded objects displays incorrect colors in all types of technical mode (RH-78040)
- CurvatureGraph clipped by custom colors (RH-77473)
- DraftAngleAnalysis: Analysis mesh does not preview (RH-73901)
- File IO:
- FilletSrfToRail: Failure caused by curve direction (RH-77869)
- GCon: Incorrectly reports G2, instead of G1, between surface edges (RH-78419)
- Grasshopper:
- Grasshopper: Components:
- Gumball:
- Help: Review, correct and improve the gumball topic (RH-44392)
- History: HistoryPurge command only removes info from children (RH-78059)
- IntersectTwoSets: Incorrectly adding objects to reference layers of Worksession (RH-78724 )
- Layer: Borders of color and material controls in are blurry in Layers panel (RH-78058)
- Lights: Light panel falloff doesn’t change on first time (RH-78311)
- LoadPlugin: Pufferfish doesn’t run in GH in Rhino 8 (RH-78382)
- Menu: : 4View menu item missing Enter in macro (RH-78023)
- OSnap: “Snap to occluded object” does not work properly in Rendered display mode (RH-78334 )
- OpenNURBS: OpenNurbs hangs in ONX_Model::Read() function (RH-77657)
- Options: File angle tolerance set to 0.01 gives an incorrect popup warning (RH-78037)
- PackageManager: Search bar has low contrast (RH-77791)
- Panels: Toolbar icons in Named panels are truncated instead of wrapping (RH-78471)
- Print:
- Gradient background repeating bands when printing in PDF (RH-63777)
- Hatch Not Printing with Print Weight (RH-77631)
- Linetypes in model units are not scaled on paper (RH-78154)
- Vector output prints shaky lines when object is far from world origin (RH-76645)
- Tabbing through margin fields may not select current value for editing (RH-16327)
- Does not remember selected layout in next print (RH-43925)
- Vector output missing geometry behind clipping plane (RH-77617)
- Vector print of clipped scene issue (RH-77106)
- PushPull: Does not recognize region bounded by curves (RH-77984 )
- Rendering: Image overexposed (RH-77923)
- Rendering: Cycles:
- Rendering: Cycles Viewport: Ignores OCS mapping (RH-76980)
- Rendering: Materials:
- Rendering: Realtime SDK: Default light gets added when light already exists (RH-78010)
- Rendering: Textures:
- SDK: CRhinoAppSettings::ShowOsnapDialog no longer works (RH-78331)
- ScriptEditor:
- Selection: Subobject selection does not work with SubDs in blocks (RH-78148)
- Sphere: Rhino.Geometry.Sphere.FitSphereToPoints not working correctly. (RH-77868)
- ToNURBS: ToNURBS of toroidal RevSurface creates invalid Brep (RH-57922)
- Toolbar:
- RUI file not registered from 8.0/MacPlugIns symlink (RH-78835)
- Rhino needs a restart to be able to delete a button (RH-77523)
- Removing a new Toolbar button does not work (RH-78350)
- Incorrect ID’s for DimRotated.svg & DimRotated_darkmode.svg (RH-78533)
- ClosestPoint icon is missing (RH-78459)
- PopupToolbar glitch with Layers (RH-78366 )
- UDT: CageEdit slow example (RH-78098)
- UI Appearance: Vertical-docked tabs don’t show text (RH-77483)
- UI Cleanup: Automatic UI sections show all sections even the empty ones (RH-78049)
- ZoomSelected: Not working on sub-selected objects inside a block instance (RH-78030)
宕机修复
- Eto: System.Exception: Could not initialize an instance of the type ‘Foundation.NSUrl’: the native ‘initFileURLWithPath:isDirectory:’ method returned nil. (RH-77593)
- FilletSrfToRail: FilletSurfaceToRail: Crash in Grasshopper (RH-74236)
- ScriptEditor: Grasshopper: Allow removal of OLD label on legacy Python script components (RH-76151)
改善内容
- Gumball:
- Print: Now shows file path and name when printing to PDF completes (RH-78524)
- PrintPreview: Added DetailBorder option to control visibility of detail view borders in layout viewports (RH-74306)
- PushPull: Added SetBasePoint option (RH-78197 )
- SelLayer: Scriptable command allows picking more objects with preselect (RH-78335)
新增特征
- ScriptEditor: Added hotkeys for adjusting font sizes (RH-75779)
- Grasshopper: Components: Data conversion failed from extrusion to surface (RH-78595)
- Offset: In Grasshopper 1 / V8, setting corner style to 0 (no extension) fails on polycurves (RH-78581)
- Rendering: Realtime SDK: Bella outputs error messages and fails to render objects (RH-78709)
- SelLayer: Cannot specify a layer when an object is selected (RH-78290)
- Subobject Selection: SubD face selection is still harder for non-planar ngons (RH-78578)
SDK (开发工具)增强
- Layer: Added publicly exported function to sort the layers in the layer table (RH-78286)
- LoadPlugin: Added support for multi-targeting plugins to have specific assemblies for .NET Core vs. .NET Framework (RH-76604)
- SDK: RhinoCommon:
达成目标
- File IO: Updated SketchUp SDK to latest (RH-78474)
UI 调整
- CPlane: AutoAlign: Auto CPlane is now disabled by default (RH-78691)
- Print: Colors of section styles override print colors (RH-78294)
仅 Mac版调整内容
- Annotation: Linetype: Default linetype panel should be taller (RH-76525)
- Display Metal:
- Export: Should deselect post selected objects (RH-78026)
- Gumball: Disappears when opening a second document (RH-77645)
- Layer:
- Layout: Move Up and Move Down buttons not responsive beyond first click (RH-77776)
- Preferences: Is made scriptable on Mac (RH-61857)
- Print: Vector output to the MS PDF Printer Produces a blank page (RH-66833)
- Rendering: Textures: Not obvious when treat as linear button is disabled (RH-78136)
- Splash and About: Allows Copy-Paste from the About dialog (RH-69006)
- LoadPlugin: Plugins: Create version-specific MacPlugIns folder and load plugins from there (RH-78149)
❖ 仅 Windows 版调整内容
- Annotation: Linetype: (Sometimes) double width on Windows (RH-78031)
- Display: Cannot cast shadows from unclipped objects when specified (RH-78193)
- Rendering: Rendering through Frame buffer increases memory usage (RH-77045)
- Rendering: Materials: Initial drag on a material causes Rhino to hang (RH-78241)
- Selection: Selection - dots and layouts (RH-78771)
- ShadedViewport: Frequently Shaders Turning Black in Rendered Mode on Rhino 8 (RH-78738)
- Options: Added link to open the new location of the Crosshairs checkbox (RH-78181)
