Rhino 8.23 (SR23)
Rhino 8.23 (SR23) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
❖ 链接: 点击这里进入百度网盘下载
- Rhino Mac 下载后直接运行安装程序即可;
链接: 点击这里进入百度网盘下载
- BlockEdit: Editing a linked file leaves a “ceflog.txt” file on disk (RH-62888)
- Curve: Changing active layer while drawing does not update preview color (RH-88368)
- Display: Selected subobject has clipped selected edge highlight (RH-79197)
- DotNET: Load MSAL.NET >4.52 for SSO broker support (RH-88608)
- Group: Only Partial Feedback Hidden Model Layer (RH-88314)
- LineTypeDisplay: Only Partial Support for RH8 Features (RH-88036)
- Print: Short Curves Print As Hatch Dots (RH-88367)
- Properties: Do not list linetypes from linked blocks (RH-88743)
- QuadRemesh: Labels at bottom are clipped because of DPI display scale (RH-88437)
- Rendering: Realtime SDK: Change Queue and Block - Event not fired (RH-88546)
- Rendering: Textures: ON_Texture simulation has wrong rotation (RH-88633)
- ScriptEditor: Code wants to compile against specified package versus inspected (RH-88430)
- SDK:
- StatusBar: Units are not displayed as fractional (RH-86734)
- UserText: Remember Attribute Text key/value column sizes (RH-88503)
UI调整
- PluginManager: Plug-in’s page needs padding (RH-88722)
宕机修复
- Panels: Import button in Linetypes panel crashes Rhino (RH-89091)
开发工具增强
- SDK: RhinoCommon: Closed mesh is seen as open mesh (RH-88560)
适应性问题修复
- Gumball: Tap Alt while extruding does not keep input surface (RH-88518)
仅 Mac 版相关错误修复
- WindowLayout: Double OSnap toolbar containers in presets (RH-80062)
