Rhino 8.28 (SR28)
Rhino 8.28 (SR28) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
,输入你的Rhino账号绑定的邮箱地址,下载更新安装包; - 下载 Windows 版离线完整安装包,下载后解压缩至一个单独文档,然后双击运行 Bootstrapper.exe 即可;
❖ 百度盘下载链接
- 下载 Mac 版离线完整安装包
百度盘下载链接
- Display:
- Edit Dimension: Periods turned into Commas In dimension text (RH-83506)
- Mesh: Flipped normals on mirrored blocks (RH-26525)
- Mirror: History Fails with Extrusion Object (RH-91262)
- Options: Rhino options typo - Miliseconds (RH-91217)
- Print: Scriptable command ignores AllLayouts (RH-91088)
- Undo: Incorrectly reselects post selected objects (RH-91128)
宕机错误
- Rendering: Cycles: Causes Rhino to disappear at startup (RH-90867)
增加特征
- Context Menu: Option to Not Include (Custom) Display Modes (RH-85649)
- File IO: Supports importing SolidWorks 2026 file format (RH-90674)
- SetDimensionLayer: Fails to Put Dim on Layer (RH-90393)
开发工具增强
- OpenNURBS: SDK Enhancement: Allows ON_TextDot overriding ON_Object::DataCRC function (RH-91145)
- SDK: Added C++ and RhinoCommon functions that split a curve using a plane (RH-91178)
- SDK: RhinoCommon:
仅
相关内容
- Display:
- File IO: “Snapshot of current view” for AI export not working properly on Mac (RH-91241)
- Properties: Cannot change layer from (varies) to Default (RH-91608)
- Rendering: Materials: Texture glitch in Rhino 8 for Mac (RH-91882)
- SDK: RhinoCommon: RhinoDoc.ExtractPreviewImage does not work on Mac (again) (RH-91280)
