Rhino8中grasshopper的python脚本执行后,返回grasshopper界面即无响应
各位大神,如下脚本在rhino 8中的grasshopper新的python 3编辑器里执行,程序功能实现正常,但执行后返回grasshopper,grasshopper界面就无法拖动,也无法重新点击进入编辑器,请问如何解决?
test.gh (16.3 KB)
‘’'python
import scriptcontext as sc
import Rhino
from Rhino import RhinoDoc as rr
import Grasshopper.Kernel as gk
import Grasshopper
import Rhino.DocObjects as rd
import System.Drawing as sd
def initalize_object():
    sc.doc = Rhino.RhinoDoc.ActiveDoc
    if not rs.IsLayer(layer): # 新增图层
        rs.AddLayer(layer)
        rs.LayerColor(layer,(255,0,0))
    # 提示用户选择图元
    objects = rs.GetObjects("请选择要拾取的图元(曲线或Brep)", preselect=True, select=True)
    if not objects:
        print("没有选择任何图元")
        return
    for geo in objects:
        # 检查图元是否是坏对象
        if rs.IsObject(geo):
            if rs.ObjectName(geo) == None or ("Invalid" not in rs.ObjectName(geo)):
                if rs.IsCurve(geo) ==True and rs.IsCurveClosed(geo) == False:
                    print ("This curve is open!",type(geo))
                    # closed_curve = rs.CloseCurve(geo)
                    # closed_curve = Rhino.Geometry.Curve.MakeClosed(rs.coercecurve(geo),0.01)
                    # print (closed_curve)
                    # sc.doc.Objects.Replace(geo, closed_curve)
                # 图元正常,改变图元图层、颜色、名称
                doc_object = rr.ActiveDoc.Objects.Find(geo)
                sc.doc = rr.ActiveDoc
                print(geo)
                rs.ObjectLayer(geo, layer)
                rs.ObjectColor(geo,color)
                rs.ObjectName(geo,str(geo))
                # 图元正常,为图元添加用户自定义属性
                for i in range(len(user_key)):
                    rs.SetUserText(geo, user_key[i], default_value[i])
                print("This object initalized successfully!")
            elif "Invalid" in rs.ObjectName(geo):
                # 图元无效或坏对象,进行炸开和重组操作
                print ("This object is Invalid !")
                exploded_objects = rs.ExplodeCurves(geo,True)
                print (type(exploded_objects))
                if exploded_objects:
                    joined_object = rs.JoinCurves(exploded_objects,True) if rs.IsCurve(exploded_objects[0]) else rs.JoinSurfaces(exploded_objects, delete_input=True)
                    print (type(joined_object))
                    if joined_object[0]:
                        doc_object = rr.ActiveDoc.Objects.Find(joined_object[0])
                        rs.ObjectLayer(joined_object[0], layer)
                        rs.ObjectColor(joined_object[0],color)
                        rs.ObjectName(joined_object[0],str(joined_object[0]))
                        # 为新图元添加用户自定义属性
                            rs.SetUserText(joined_object, user_key[i], default_value[i])
                    else:
                        print("无法重新组合图元")
                else:
                    print("无法炸开图元")
        else:
            print("无效的选择")
    sc.doc = ghdoc
# 调用主函数
if Switch:
    initalize_object()
请在 Rhino 指令行执行 SystemInfo, 然后把弹出内容拷贝后粘贴回帖。
另外请私信回复一下你当前 Rhino 的授权码 (以 RH70或 RH80开头的一组字串)
