在rhino编辑中经常能看到scriptcontext的使用,但是鄙人愚笨找不到对应的说明,就很迷惑
scriptcontext模块没有说明,因为它本身也没有多少代码。你可以在安装文件里找到scriptcontext模块的源代码:
# scriptcontext module
import RhinoPython.Host as __host
'''The Active Rhino document (Rhino.RhinoDoc in RhinoCommon) while a script
is executing. This variable is set by Rhino before the exection of every script.
doc = None
'''Identifies how the script is currently executing
1 = running as standard python script
2 = running inside grasshopper component
3... potential other locations where script could be running
id = 1
'''A dictionary of values that can be reused between execution of scripts
sticky = dict()
def escape_test( throw_exception=True, reset=False ):
    "Tests to see if the user has pressed the escape key"
    rc = __host.EscapePressed(reset)
    if rc and throw_exception:
        raise Exception('escape key pressed')
    return rc
def errorhandler():
    The default error handler called by functions in the rhinoscript package.
    If you want to have your own predefined function called instead of errorhandler,
    replace the scriptcontext.errorhandler value
    return None
__executing_command = None
def localize(s):
    import Rhino
    if __executing_command is None:
        return Rhino.UI.LocalizeStringPair(s,s)
    assembly = __executing_command.PlugIn.Assembly
    l = Rhino.UI.Localization.LocalizeString(s, assembly, -1)
    return Rhino.UI.LocalizeStringPair(s,l)
开发者为了方便大家使用,做了一个简单的封装。scriptcontext.doc应该是最常用的功能,这个是对Rhino.RhinoDoc.ActiveDoc内常用方法的封装,你也可以使用Rhino.RhinoDoc.ActiveDoc。
scriptcontext.sticky这个是开发定义了一个字典,我一般都是用开发者定义的这个,你也可以自己定义。
scriptcontext.escape_test做了一个按esc键退出程序的功能,偶尔可能会用到。
别的几个功能,我基本上没咋用到过。
          感谢月神,嘿嘿,受教啦
