进入food4rhino安装shap map插件,启动rhino提示如下:
请坚持ixia是否有多个位置加载过 ShapeMap , 如果确定没有就是和其他插件有冲突,在Food4Rhino 的 ShapeMap 页面也有重要的提醒,
Important: This plugin is still under development and conflicts with some other encrypted plugins. When it exists together with some plugins, it may cause Grasshopper not to start correctly. When a conflict occurs, if you want to continue using ShapeMap, temporarily disable the conflicting plugin(s) and restart Rhino.
这样意味着要麻烦你你手动逐一检查,看看和那些其他插件冲突造成。
