遇到一个问题,犀牛导出的dxf,其他软件识别不了,需要去到cad里面转换下。
不知道犀牛可以在哪里设置导出为AAMA格式? 还是根本没有这个功能? 谢谢!
https://discourse.mcneel.com/t/export-file-for-modaris-lectra-need-dxf-aama-or-astm/9708/5
简单搜了一下,试试看这个帖子的办法好了
不过我也不确定是否能解决
谢谢!
哈~我也是给clo3d用的。。
大概明白了要图块模式。
block后导出,导入clo3d时不出现警告提示了,但没有东西进去。。。 ![]()
Not sure about ASTM, but I have a lot of success with dxf-AAMA
AAMA is really just DXF with a few layers conventions.
The main thing with exporting a aama file is the layers table:
Boundary Lines: 1
Grade/turn points:2
internal lines (draw):8
Internal Cut: 11
Notches: 4
Drills: 13
Base (grain) lines: 7
Sew lines: 14
Quality lines: 15
mirror lines: 6
The other thing to watch out for is the DXF export scheme you use. Depending on the version of Modaris you are sending to, you will have varying degrees of success with splines. So I’d suggest trying a polylines export scheme and fiddle with the tesselation parameters until you get a good balance between accuracy and density.
不确定ASTM,但我在dxf AAMA方面取得了很大成功
AAMA实际上只是具有几个图层约定的DXF。
导出aama文件的主要内容是图层表:
边界线:1
坡度/转弯点:2
内部线条(绘制):8
内部切割:11
槽口:4
钻孔:13
基底(纹理)线:7
缝线:14
质量线:15
镜像线:6
要注意的另一件事是您使用的DXF导出方案。根据您发送到的Modaris版本,使用样条线将获得不同程度的成功。所以我建议尝试多段线导出方案,并修改细分参数,直到在精度和密度之间获得良好的平衡。
We export DXF AAMA often from Rhino.
It is well explained by@Steve_Howden, the only thing you need to add to that is make sure that once the part is finished, all layers of the part are selected and made into a DXF Block (‘block’ command in Rhino) and that block is on a layer other than any of the instruction layers (1,8, 11 etc) . So put the block onto a layer called ‘fabric’ for example.
我们经常从Rhino导出DXF AAMA。
这是很好的解释by@Steve_Howden,唯一需要添加的是确保零件完成后,零件的所有层都被选中并制作成DXF块(Rhino中的“块”命令),并且该块位于除任何指令层(1、8、11等)之外的层上。例如,将块放在一个称为“fabric”的层上。
指令层又在哪里?
具体他说的什么意思 建议你还是去原贴回复询问。
