rhino7.34用rhi安装成功后,显示Error Loading .rhp
请参考这里的解决方案 https://wiki.mcneel.com/zh/rhino/5/rhi-problems
提醒: .rhi 需要正版 Rhino授权的支持!
是如下这样,可以指导下具体是什么问题吗?
----- Summary -----
A fix was applied to your computer.
Version 7 (x64) of the Rhino Installer Engine will install packages for Rhino 7 and older.
RhiFix.exe version 6.0.6726.16913 starting…
------Details------
- Detecting Rhino Installer Engine Executable … 7.34.23267.11001
- Detecting Rhino.InstallerPackage registry key in HKLM … 7.34.23267.11001
- Detecting .rhi registry key in HKLM … found.
- Detecting Computed .rhi File Association … 7.34.23267.11001
- Detecting User .rhi File Association (Windows 7) … not found.
- Detecting User .rhi File Association (Windows 10) … not found.
- Detecting 32-bit Rhino 5 … not found.
- Detecting 64-bit Rhino 5 … not found.
- Detecting Rhino 6 … 6.7.18199.22081
- Detecting Rhino 7 … 7.34.23267.11001
- Detecting File association mismatch … not found.
- Fixing .rhi registry key in HKLM … succeeded.
----- Data -----
- rhiexec_installed_version = 7.34.23267.11001
- rhiexec_install_path = C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe
- rhiexec_exists = True
- rhiexec_platform = x64
- rhi_system_registry_open_command = “C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe” “%1”
- rhi_system_registry_open_command_path_exists = True
- rhi_system_extension_registry_key_found = True
- rhi_system_extension_registry_class = Rhino.InstallerPackage
- rhi_file_association_exists = True
- rhi_file_association = C:\Program Files\McNeel\Rhino Installer Engine\x64\rhiexec.exe
- rhiexec_associated_version = 7.34.23267.11001
- v6_install_path = C:\Program Files\Rhino 6\
- v6_version = 6.7.18199.22081
- newest_rhino_version = 7.34.23267.11001
- v6_install_path_exists = True
- v7_install_path = C:\Program Files\Rhino 7\
- v7_version = 7.34.23267.11001
- v7_install_path_exists = True
请把你的 Rhino 7 授权码单独发送给我,我有给单独私信你。
