Rhino 8.10 (SR10)
Rhino 8.10 (SR10) 发布更新,所有 Rhino 8 的用户都会自动下载更新安装包,且会适时提示安装更新。 如果自动更新被阻止,请尝试下面的方式手动更新
- Rhino Mac 下载后直接运行安装程序即可;
❖ 链接: 点击这里进入百度网盘下载
链接: 点击这里进入百度网盘下载
- OSnap One Shot incorrectly remains disabled (RH-82829)
- BlockEdit: Adding group objects to a block maintains relationship with group. (RH-82921)
- BooleanDifference: Normal direction flipped on a mirrored block (RH-82669)
- BooleanUnion:
- BoxEdit: Panel gets disabled until additional click (RH-82612)
- Bridge: Causes creases to be removed (RH-82462)
- Cap: Bails when all mesh faces are coplanar (RH-82671)
- ClippingPlane: Causes a crash (RH-81765)
- Code Editor Control: C# autocompletes null) to Nullable) when close bracket is typed (RH-82575)
- CreateSolid: Supports History when DeleteInput=No (RH-13146)
- Dir: Only one object is flipped when multiple objects are selected (RH-82599)
- Displacement: Addition texture gives different results in raytraced (RH-75365)
- Display:
- Section Color is Wrong in Arctic (RH-82893)
- Changing surface direction does not update texture (RH-74064)
- All procedural textures are calculated on GPU (RH-36299)
- Render mesh does not update when editing sharp edges (RH-82765)
- Extra Block Instance Section Hatch In Technical Display Modes (RH-82637)
- Locked detail camera moves (RH-82390)
- Technical mode is constantly printing “Updating wire cache”… (RH-82657)
- Lines parallel to view direction of plan view are not visible (RH-62347)
- DocumentProperties: Changing units via -documentproperties throws an exception. (RH-83230)
- EdgeSoftening: Stops working (RH-82987)
- Emap: Mesh setting is ignored (RH-82838)
- ExtractClippingSections: Sectioned objects incorrectly added to output group (RH-81221)
- File IO:
- FillMeshHole: Creates various results (RH-82897)
- FilletEdge: Editing radii not starting with saved handles (RH-82515)
- Grasshopper:
- Grasshopper: Components:
- GrasshopperBlocks: Blocks show their transform axis in Monochrome/Arctic display mode (RH-82674)
- Gumball:
- History: Parent-Child Not As Expected (RH-64470)
- Layer: Layer pane shows wrong layer when a worksession attached object is selected (RH-82857)
- Layout: Chinese dialog for layout is clipped (RH-82955)
- Lights: Slider value in Light properties gets divided by 1000 (RH-82466)
- Localization: Commands.rhp not loaded if regional format is set to Thailand (RH-83005)
- MacroEditor: Macros run from the MacroEditor are not repeatable on the Mac (RH-82882)
- Mesh:
- MeshPolyline: Normal Direction/Inconsistency (RH-82193)
- NamedView: Grid settings lost (RH-1575)
- Paste: Pasting from AutoCAD Uses Wrong Coordinates (RH-82933)
- Print:
- New Rhino session forgets last printer used (RH-82949)
- Join Style Issue with Vector Preview/Printing (RH-82720)
- Printing specific Layout in Multi-Layout print always prints first layout (RH-82805)
- Vector Print of Curves Messes with Ends (RH-82579)
- Vector Print does Not Occlude Curves (RH-82576)
- Vector output with clipping plane text mask showing (RH-82587)
- Rendering: Cycles: OCS texture mapping broken in Cycles (RH-66048)
- Rendering: Environments: Skylight intensity turns to -1.00 when physical sky texture does not have an intensity parameter (RH-82366)
- Rendering: Materials:
- Rendering: Post Effect: Modifying RenderWindow contents after render doesn’t work properly (RH-81122)
- SDK:
- SDK: RhinoCommon:
- ScriptEditor:
- Section Style: F1 Help Leads Nowhere (RH-82549)
- Section Tools: ApplyToAll=Yes should not change Placement Point (RH-80646)
- SelectionFilter: Container pops up when already docked (RH-82558)
- ShutLining: Multiple mesh modifiers create a bad render mesh (RH-28101)
- SplitDisjointMesh: Doesn’t preserve UVs (RH-82825)
- SubD: Slow unresponsive when assigning color to face (RH-82907)
- Sun:
- Toolbar: Deleted Macros Come Back (RH-81456)
- UI Cleanup: Layer popup reopens when last layer is clicked (RH-82653)
- ViewCaptureToFile: Default to PNG and make extension stick (RH-65583)
- Zebra: UI focus is lost easily (RH-82116)
- OpenNURBS: Makefile is not able to compile examples on Linux; android_uuid missing (RH-82660)
宕机修复
- Annotation: Hatch: Rhino 8 keeps crashing when creating hatches (RH-82935)
- Code Editor Control: C# editor crashes in Rhino 8 (RH-83060)
- Crash: in CRhinoDisplayEngine_OGL::ShowBackBuffer (RH-81020)
- Display: Crash in CRhVboChunkMetal::SetupVertexBuffer (RH-82682)
- Make2D: Cannot cancel properly (RH-78990)
增强内容
- Block: Groups can be saved in block definitions (RH-39190)
- ClippingPlane: Copies of a named clipping plane get incremental suffix numbers in their names (RH-79425)
- Code Editor Control: Optimized completion list sorting order in C# (RH-80524)
- Drag and Drop: Python - support script drag and drop (RH-82540)
- File IO: DWG/DXF export supports writing degree 1 curves (RH-82317)
- Section Tools: NestedClippingDrawing: All option now creates clipping section drawings ordered by section names in alphabetical order (RH-77581)
- TextField: Allows using “” as object ID for referencing the object itself in Attribute User Text (RH-82648)
增加特征
- File IO:
- Section Tools: Changing clipping plane name updates associated clipping drawings, layers, named views, and named CPlanes (RH-75371)
- Display: Linetypes don’t show segments when far from origin (RH-81516)
- OffsetSubD: Error on scaled SubD Plane (RH-82665)
- Print: Hardware settings being lost (RH-81693)
- Rendering: Textures: WCS/OCS mapping gets scaled with blocks (RH-82266)
- ScriptEditor: RunScript should enable Redraw after running (RH-83100)
- Trim: Failure case in v8 (RH-78036)
- UI Cleanup: Layer popup lost focus after changing color of layer (RH-82977)
SDK 增强
- SDK: Exposed RhStartedAsRhinoExe to C++ SDK (RH-82701)
- SDK: RhinoCommon:
- ScriptEditor: Implemented RhinoCommon PythonScript in new rhinocode (RH-81267)
UI 调整
- Properties: Added display mode setting to viewport properties for active detail view (RH-82456)
- UserText: UI improvements for Block Attribute Text in Attribute User Text properties (RH-82760)
- ViewCaptureToFile: Removed jpg and bmp formats from Save dialog when transparent background is enabled (RH-42926)
适用性问题修复
- MatchProperties: Hatch should match other properties - not just hatch properties (RH-27591)
- ScriptEditor:
- Bring back Collapse to Definitions (RH-82703)
- Published contextual component does not preview output geometry (RH-79902)
- Added options to UI to use tabs vs spaces and to set the tab/space size (RH-82525)
- Private members of Script_Instance are not in the editor so there is no autocompletion for them. (RH-81585)
仅 Mac Rhino 相关
- Display: Grid lines thicker in shaded mode (RH-82880)
- Polyline: Enter to finish command fails when using command option window (RH-82680)
- SubD: Sharp edges are lost when copy-pasting (RH-82577)
- UI Cleanup: Right click menu in layer popup does not work on Mac (RH-82976)
- Units: Infinite dialogs pop up on doc close if layout units are not inches or mm on Mac (RH-83058)
- ViewCaptureToFile: Transparent background forces png format (RH-82581)
宕机修复
- AutoSave: Corgi package causes macOS Autosave hang requiring Force Quit (RH-81891)
增强内容
- MatchSrf: Made OK button focused by default instead of Distance field (RH-82468)
适用性问题修复
- ScriptEditor: MacOS menu is confusing (RH-82727)
❖ 仅 Windows Rhino 相关
- Display: OpenGL 2.1 does not display arrowheads of dimension lines (RH-82480)
- Eto: Rhino 8 in .Net 8 (rhino.Inside.Revit 2025) UI jump (RH-81674)
- Keyboard Shortcuts: Keyboard Shortcut: Ctrl+Shift+M needs pressing twice to run macro (RH-82780)
- Rendering: Materials: Switching Issue in Worksessions (Always in this case) (RH-82707)
- SelName: Dialog Version Shows No Names from Attached Files (RH-82886)
宕机修复
- File IO: SKP Import Crashes Rhino 8.9, 8.10, and BOTD (RH-82833)
- Print: Crash with Vector Output (RH-82980)
- ReadViewportsFromFile: Ignores environment strings (RH-82719)
增强内容
- File IO: DWG/DXF import detects and resolves conflicted block names (RH-82252)
- ChangeLayer: Can’t click on right side to change layer (RH-82762)
- StatusBar: Layer popup blocks Layer pan (RH-82747)
适用性问题修复
- Grasshopper: Parameter input keyboard shortcuts required enter or space to complete (RH-82929)
