我更新了rhino8, 但是发现使用截平面(clippingplan)时,会崩溃
如果文件很小还可以使用,但是一般工作文件都比较大,所以没法使用
我的电脑是i7 14700KF+4070Ti super
我尝试更新了显卡驱动并换了不同的rhino版本(8/8.1/8.2/8.3/8.4)但每次都崩溃
如果我在设置中更改"OpenGL" 从“Max OpenGL可用”改为“OpenGL 3.3”,就不会崩溃但是很慢
此前使用显卡测试软件跑过分,应该不是硬件的问题
希望哪位大神能帮助解决或官方可以修复这个“bug”
谢谢!
请在 Rhino8 指令行执行 SystemInfo, 然后把弹出内容拷贝回帖。
您好,这是我弹出的信息:
Rhino 8 SR4 2024-2-13 (Rhino 8, 8.4.24044.15001, Git hash:master @ 5d3f86ffffae3c2ed84d21147c008b3907a40a2e)
License type: Commercial, 版本2024-02-13
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Standard graphics configuration.
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Ti SUPER (NVidia) Memory: 16GB, Driver date: 2-7-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.52
> Accelerated graphics device with 4 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-7-2024
Driver Version: 31.0.15.5152
Maximum Texture size: 32768 x 32768
Z-Buffer depth: 24 bits
Maximum Viewport size: 32768 x 32768
Total Video Memory: 16376 MB
E:\Program Files\Rhino\plugin\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\BX\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.23328.1419
C:\Users\BX\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino 渲染” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24044.15001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
请你尝试执行 PluginManager, 然后弹出窗口找到下面这些插件,取消勾选后重启Rhino8 再试试
- BlockEditNew.rhp
- Enscape.Rhino8.Plugin.dll
- D5Conv.rhp
这些操作仅在开启一个 Rhino8 视窗的时候进行
您好,禁用了上述插件,可以使用,但使用clippingdrawing时,CPU 变成100%,之后就无响应了。
另外,这意味着我无法同时使用插件和截平面功能吗 ![]()
你需要从这几个插件中查找具体是哪个插件冲突,然后将这个问题反馈给插件开发者,如果你购买了正版的插件授权与Rhino授权。 如果没有…你说的是对的。
好的,明白了,十分感谢!
