各位大佬好,我实在找不到答案了,最近配了一台ITX主机,配置算是比较高了 CPU 13700K 显卡4080S,内存64G,但是我发现运行一个100MB图纸的时候非常卡顿,但是我同时也试了我的老笔记本(注意,还是笔记本)配置是 CPU i7 9750H 显卡2070RTX,内存32G,就这,同一个文件,在笔记本居然比我的ITX台式小主机好很多,顺畅很多,为什么啊!是不是哪里设置有问题,希望大佬帮我解答,我的联系方式是yanndesignstudio(微信),感激不尽!!
请在 Rhino 指令行运行 SystemInfo 指令,然后把弹出内容拷贝后回帖
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Commercial, 版本2023-11-21
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Computer platform: DESKTOP
Standard graphics configuration.
Primary display and OpenGL: Intel(R) UHD Graphics 770 (Intel) Memory: 128MB, Driver date: 5-22-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5535
> Integrated graphics device with 4 adapter port(s)
- Windows Main Display attached to adapter port #0
Secondary graphics devices.
NVIDIA GeForce RTX 4080 SUPER (NVidia) Memory: 16GB, Driver date: 7-30-2024 (M-D-Y).
> Accelerated graphics device with 4 adapter port(s)
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
- Recommended: Unplug the monitor and plug it into one of the video ports on this device:
[NVIDIA GeForce RTX 4080 SUPER]
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.5535
Driver Date: 5-22-2024
Driver Version: 31.0.101.5535
Maximum Texture size: 16384 x 16384
Z-Buffer depth: 24 bits
Maximum Viewport size: 16384 x 16384
Total Video Memory: 128 MB
D:\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
D:\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit”
D:\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino 渲染” 8.1.23325.13001
D:\Rhino 8\Plug-ins\RhinoRender.rhp “旧版本 Rhino 渲染器”
D:\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
D:\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots”
D:\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
D:\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
D:\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
D:\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
D:\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
D:\Rhino 8\Plug-ins\Displacement.rhp “Displacement”
D:\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
来了,请大佬救我狗命!
你好,貌似发现问题了,就是我是便捷屏,用的是type C的接口接的主板上的雷电4接口,没有用数据线直接接独显插口,但是貌似可以让犀牛用独显优先吧(即便是接口没有直连独显),因为我玩游戏的时候也是这么插的,独显工作没有问题
请更新至最新的 Rhino8.10 Rhino 8.10 (SR10) 发布更新
可以,你可以在 Nvidia 显卡设置中设置 Rhino.exe 跑独立显卡
设置了好像依旧不管用,是不是TYPE C一线通无法支持独显输出
据我所知,某些高端主板有两个 typec 视频输出口,当独立显卡 连 DP 线到主板上 (DP IN) 时,只有其中一个 typec 通过独立显卡输出,另一个是通过 CPU 集成显卡输出,这个你要查看主板说明书
注意:
台式机正在使用速度较慢、可靠性较差的集成图形设备,可能需要更改配置。
仅检测到一个监视器,但它连接到速度较慢的集成图形视频端口。
建议:拔下显示器并将其插入此设备上的视频端口之一:
[英伟达GeForce RTX 4080 SUPER]
您所做的任何硬件配置或布线更改都需要重新启动 Rhino。
对的我也看了,也就是说便捷屏TYPEC 没办法在使用犀牛的时候直接调用独显,等于我的独显根本没工作,一直以集显工作,,,,
是的,我发现好像TYPEC 雷电4接口没办法独显直连显示器,所以我的电脑其实默认都是以集显在跑,(除了玩游戏的时候)
我印象里在英文论坛有人和你有类似的问题,原帖我找不到了,大致是因为供电和视频在同一条线路中输出导致的问题,当C口线同时承担供电和视频输出时,其视频输出性能会大打折扣。
